Lubrication question
Old Jul 12, 2011 | 06:28 PM
mi2az's Avatar
mi2az
Default Lubrication question
Doing the final touches on my 10K. This is my First Harley.
I have a can of white lithium grease. It appears to be very light, almost like a WD-40.
I want to lubricate the hinges on my hard cases and floor boards, hinges and latches.
Is the can of white lithium what you guys recommend ? HD only gives part numbers and not the actual name of the grease type I would be using.
So what would you guys suggest to get for the applications I want to use it for ?
Old Jul 12, 2011 | 06:34 PM
dawg's Avatar
dawg
I shoot all my hinges and floorboards with Dri-Slide
dawg's Avatar
dawg
Do not forget to lubricate the springs on the inside of the saddlebag latches. They rust out and break quite often on folks that do not remember to service them.
Old Jul 12, 2011 | 06:37 PM
mi2az's Avatar
mi2az
Thanks for that tip. Is that where the hard bags attach to the bike, the part that you twist onto a thin spring ?
Old Jul 12, 2011 | 06:48 PM
dawg's Avatar
dawg
This is the spring, you'll see it when you open the latch
Old Jul 12, 2011 | 07:02 PM
mi2az's Avatar
mi2az
thanks
Old Jul 12, 2011 | 08:23 PM
lh4x4's Avatar
lh4x4
White lithium grease would be great for the hinges. It does not dry out. Sometimes it is called bicycle grease as it is used in all the bearings in high end bikes. Out board motors use it in friction areas also.
I use so much that I get it in one pound tubs.
Gritz72
Feb 16, 2017 09:37 PM
Bobby12012
General Topics/Tech Tips
Jan 13, 2014 09:26 PM
customclimates
Jul 17, 2010 01:57 PM
shearpinn
Jun 14, 2007 11:13 AM
Garemlin
Mar 15, 2007 04:56 PM
