Psi how often?
Old Jul 19, 2011 | 09:55 AM
ThreatLevel Midnight's Avatar
Default Psi how often?
So I've ridden practically every day for the last 2 weeks or so. Two weeks ago my front was at 41 psi. So I just checked it again yesterday and it was down to 33.
How often do you REALLY check your tires? I know the correct answer is before EVERY ride, but what's your true answer? Mine has now changed to "much more often".
Old Jul 19, 2011 | 09:59 AM
Morris9982's Avatar
Morris9982
I check both my car and my motorcycle once a week along with the oil level.
Rarely does the level decrease. The tire pressure does seem to go down very slowly and I attribute that to the loss from checking the pressure.
If your motorcycle tire lost eight PSI in two weeks, you might want to check for a slow leak.
Old Jul 19, 2011 | 10:07 AM
Crex39's Avatar
Crex39
I generally check once a week very thoroughly while washing and p.m. I will check after a ride of 200 miles or more.
Old Jul 19, 2011 | 10:14 AM
Ed Vanharley's Avatar
Ed Vanharley
I don't check as much as I should, It's a pain in the azz. Harley, Wake up and put tire sensors on the bikes already!
Just thinking, anybody know of an aftermarket company that does this
Old Jul 19, 2011 | 10:19 AM
Sonicgazi's Avatar
Sonicgazi
haha, it's been a few weeks. Almost a month really. I should probably do that next time I ride. Thanks for the reminder.
Old Jul 19, 2011 | 10:21 AM
Wide_Open's Avatar
Wide_Open
About once a week or so. I usually need to add air maybe once a month.
Old Jul 19, 2011 | 10:25 AM
32vld's Avatar
32vld
Two weeks 8 lb loss is a lot.
My son's nightster loses about 1 lb a month.
Also temp effects pressure, you check pressure mornings or evenings when the bike has not been in parked direct sun or riden so psi reading will be at consistent temp.
Old Jul 19, 2011 | 10:27 AM
Ed Vanharley
Hey if you do a search you will find several company's that sell tire pressure monitor systems for motorcycles about $200
Old Jul 19, 2011 | 02:09 PM
SUPRPIG's Avatar
SUPRPIG
Once a week and before any 200 mile plus trips. More often in dramatic temp changes.
Old Jul 19, 2011 | 02:14 PM
kzoo's Avatar
kzoo
Once a week here, in the morning when it is cooler outside. Not consistent on day of week, only when the rear is accessible!!!
