Torque wrench question
Old Nov 23, 2006 | 01:27 PM
petemac's Avatar
petemac
Default Torque wrench question
I was reading my service manual and when it comes to torque setting for bolts and such
everything seems to be in a range, like 14-21 ft lbs as an example. Is this just a range
that you can use? So anything from 14-21 ft lbs is ok? Why don't they just give an exact
seeting to use? Like 18 ft lbs?
Old Nov 23, 2006 | 01:57 PM
BigGeorge's Avatar
BigGeorge
Default RE: Torque wrench question
I guess they are telling you that anything between the low limit and the upper limit is acceptable. This would be especially true if you were installing a castle nut where you needed to align a hole in the bolt for a cotter pin. Also some manufactures use the lower limit for dry threads and the upper limit for lubricated threads but they usually specify this. In the case where it gives you an upper limit and a lower limit and no other specifications I just split the difference like you mentioned........................BG
Old Nov 23, 2006 | 03:37 PM
DGlide04's Avatar
DGlide04
The higher in the recommended range you go, the more chance you run of stripping out the fastner. The MoCo gives a range of values because 1) not everyone's equipment indicates the same torque 2) the condition of the fasterners on each bike are subject to other conditions, damage, etc. and 3) not every value is the right one for every bike. Stay to the lower values, use a good thread locker for your fastener (make sure it is the correct one, Locktite red, blue, etc.) and you'll never have to worry about overtightening the fastner.
Old Nov 23, 2006 | 03:51 PM
KeithB's Avatar
KeithB
Big Kahuna HDF Member
ui usally go about 1/2 way in between. That 14-21 sounds like drain plugs, i use 20 for that
Old Nov 23, 2006 | 04:00 PM
liltrk's Avatar
liltrk
Isn't this backwards? A lubricated fastener should be torqued LESS because it turns easier. According to my book, an oiled bolt should be torqued 80% of the spec'd value, Dri-lock 203 (similar to Loctite) at 55%.
Old Nov 23, 2006 | 04:18 PM
BigGeorge's Avatar
BigGeorge
ORIGINAL: liltrk
Thanks for catching my error I had it back a$$wards.....................BG
Old Nov 23, 2006 | 06:48 PM
wnogood's Avatar
wnogood
ORIGINAL: KeithB
Exactly. Keeping in mind the habitual loosening of fasteners on our bikes due to vibration, I would err to a lower torque, but use a temporary type threadlocker where possible. Obviously, drain plugs are not one of those places where threadlocker is a great idea, but most everywhere else is. The blue loctite is what I use and now it comes in a handy stick-type dispenser. Much easier to use and virtually no mess. I work on automobiles avery day, and offering up such a broad range for torque values does seem strange, but in my opinion, middle ground seems best.
nogood o~`o
Old Nov 23, 2006 | 06:51 PM
KeithB's Avatar
KeithB
ORIGINAL: wnogood
ORIGINAL: KeithB
nogood o~`o
same here pretty much use blue on everything unless red is a must
i also go over the bike once in while and check fasteners
Old Nov 23, 2006 | 09:02 PM
petemac's Avatar
petemac
Thanks for the replies.
oldtoad
General Topics/Tech Tips
Apr 4, 2019 06:21 PM
priceamp
Ironhead
Aug 12, 2014 10:09 PM
Tedjay
Mar 9, 2013 10:27 PM
ShortFatMexican
Apr 9, 2010 05:07 PM
st john
Apr 23, 2007 08:07 AM
