Decel pop / backfiring
Old Sep 30, 2011 | 11:11 AM
cowboy-bc's Avatar
cowboy-bc
I had the same problem. Change column 1, 0 throttle to 0 up to 1500 rpm
Old Sep 30, 2011 | 06:56 PM
turbostang's Avatar
turbostang
It's a long shot, but check your exhaust studs. I had decel popping and sluggishness show up out of nowhere last week on the way to work. Checked the bike over when I got to work and found a stud sheared. Just dropped it off a couple hours ago to get fixed. Good luck.
Old Sep 30, 2011 | 07:05 PM
cbrenthus's Avatar
cbrenthus
When was the last time you cleaned the filter?
Old Oct 1, 2011 | 09:27 PM
Account Retired's Avatar
Account Retired
Just replaced the fuel filter and air filter a month ago. Not sure which one you are referring to.
Old Oct 1, 2011 | 10:15 PM
pugster's Avatar
pugster
try your faceplate buttons. turn on key press all three buttons at ounce and hold down then start bike. press low once to c wear its set center will show two bars i have my low set on bar above center and so on with mid and high rpm range. no popping at all.
Old Oct 1, 2011 | 10:29 PM
cbrenthus's Avatar
cbrenthus
Air filter, thought you had a heavy breather. Dirty air filter can make it run a little rich
Old Oct 1, 2011 | 11:03 PM
Account Retired
I hate to say this, I have no idea what that means..... There are no buttoms on a PC3 USB
Old Oct 2, 2011 | 12:24 AM
truckerdave's Avatar
truckerdave
senior experienced all-knowing leader of the unwise
There are 3 buttons for fuel adjustment on the front of PC3 USB. The PC5 is the one with no external buttons.
Old Oct 2, 2011 | 12:25 AM
Gutman's Avatar
Gutman
If you had no decel pop for a week the problem is not in the PC. Check for intake leaks. If the problem is with the PC take the "0" percent throttle setting from 1500-5000 setting and set it to -10. See what happens. No pop. PM me if it does.
Old Oct 2, 2011 | 05:09 AM
hockey8787's Avatar
hockey8787
Would you do this on the fuel or the ignition table???
