motor knocking
Old Nov 27, 2006 | 11:10 PM
pablo pelon's Avatar
pablo pelon
Default motor knocking
okay here'sthe problem .2002 roadking 30k miles I have a knocking in the crank case .I've had people say synthetics made their bike knock ,so I went back to HD oil .That did'nt help.Checked the primary chain tension nope not that . Now i hear there is a nut on the crank that can back off 1/4 turn and cause cause the knock.The guy said it's under the timing cover ,took that off and don't see anything . HELP !!! with Christmas coming momma says I can't spend $ on repairs.The sound is definitly coming from the front crank housing.
Old Nov 27, 2006 | 11:14 PM
Eyespy's Avatar
Eyespy
From: Southern California High Desert, here and there....
Default RE: motor knocking
Going out on a limb a little here, but just for the halibut, you sure it's not a broken front motor mount makin the racket?
Old Nov 27, 2006 | 11:28 PM
pablo pelon
wishfull thinking but it's coming from inside the motor.Had a manual but screwed up and lent it out then it grew wings and isn't where he put it last.
Old Nov 27, 2006 | 11:32 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
FYI, no oil causes mecanical problems......lack of oil or really dirty oil causes mechanical problems. You better get that bike to the shop ASAP.
Old Nov 27, 2006 | 11:33 PM
grumpy irish again's Avatar
grumpy irish again
the nut is on the other side had a couple of friends had the same noise just retighten the nut and every thing is ok
[IMG]local://upfiles/5757/7B06103E0DBB4A7BAC7ED8EC7CBA5F6F.jpg[/IMG]
Old Nov 28, 2006 | 12:18 AM
pablo pelon
grumpy is this something i can do myself with a manual? can this be done in a short amount of time with mechanicly(sp) inclined help?
Old Dec 3, 2006 | 12:02 AM
pablo pelon
That was it .took the primary cover off and retightened the 1 1/4 nut on the crank . She runs great thanks to all.
Old Dec 3, 2006 | 12:09 AM
DougsDyna's Avatar
DougsDyna
ORIGINAL: pablo pelon
HDF comes through, again............ Glad you got 'er fixed no $$$.
DougJ
adelii
May 20, 2014 04:31 PM
smokindave
Apr 14, 2013 01:43 PM
2001SOFTY
Exhaust System Topics
Jun 2, 2008 07:58 AM
AIRBORNESNIPER
Jul 7, 2007 02:22 PM
razehog
Oil Archive (no new posts)
Jun 15, 2007 05:25 PM
