Battery keeps draining
1.) Disconnect the Battery Ground Cable(s) from the Battery so that there are NO wires touching the Negative Terminal of the Battery.
2.) Make sure everything is turned off! (Very Important).
3.) Connect a Test Light between the Battery Negative Terminal and the disconnected Negative Battery Cable. Leave the Test Light connected for the rest of this test. If it becomes disconnected at any time, for any reason, restart the test from this step.
4.) Connect a Jumper wire between the Battery Negative Terminal and the disconnected Negative Battery Cable. (The jumper wire is now in parallel with the test light. The purpose of the jumper wire is to let any timer circuits in any of the electronic circuits to time out. If this is not done, the normal operation of various electronic timer circuits will have you falsely condemning one or more electronic boxes on the bike such as the TSS/TSSM, the ECU, etc.)
5.) After a minimum of 30 seconds remove the Jumper wire, but DO NOT remove the Test Light.
6.) If the Test Light is now glowing, even if it is glowing so faintly so that you have to cup your hands around it to see it, there is an excessive parasitic draw. No light means that there is NOT an excessive parasitic draw. Essentially you are using the Test Lamp as a cheap Ammeter. It takes a little bit more than about 35 milliamperes (0.035 Amperes) to make a Test Light filament glow. A current draw of less than 35 milliampers, such as the Voltage Regulator, Computer, Speedometer TSS/TSSM, etc normally consume is not enough to cause a problem.
7.) If the Test Lamp is on or is glowing even faintly, there is an excessive parasitic current draw. If this is the case more work is needed. If the Test Lamp is NOT on, you have a battery with an internal short . . . replace the battery and all will be well.
8.) If the Test light was on or was glowing even faintly there is an excessive parasite current draw. To find the offending item:
8B.) If all the fuses are pulled and the test light is still illuminated (even faintly) then you have a shorted diode in the voltage regulator. Replace the Voltage Regulator.
