Yeah, and you've been putting that tool collection together for how many years?
I'm sure most bikes aren't worth the value of what you've got in those boxes!
You'd be surprised , I paid retail for 2 of those the rest have been acquired through garage , estate and company closure sales . I'm a hustler I like and use top quality stuff but be damned if I'll spend a lean nickle more that I have to for it . Be very surprised at what you can accomplish with limited cash and the right mindset .
And yah that's a skinny drawer you should see the full ones . I'm bad I know
That KD looks like a good wrench, but unless you plan on several like TwiZted's got, I think you'd be better off with a wrench with a little more range than 10-50 in lbs. That's only a little over 4 ft. lbs. at it's upper limit. Something with a range of 25-250 in. lbs. is probably a little more versatile.
What's the lower range of your "big" wrench? Is your "big" wrench a half-inch drive ft. lb. wrench? If so, I have a feeling your going to have quite a gap between the two.
Just something to consider.
For the average garage guy I'd say you need 2 , one in 1/4" and low in'lbs and one 3/8" drive with highers settings like you mention the 25-250 or higher range . That will cover 95% of what most guys will ever run into in a home garage . 1/2" is nice but you might use it once a year ??
Guys I'll apologize I'm a builder so nothing on a motor or drive train goes past me without the proper torque wrench used on it , and I applaud anyone who has the sense to want to do it right and ask's about the right tools . Don't look at my over the top stuff as intimidating please make it a target to achieve instead
I like choices myself , right tool for the job kind of thing I'm a bit **** about that
You still need one of the cheap bender bar style lb/in 1/4" drive torque wenches for measuring turning torque when setting up tapered roller bearings. But you sure do have at least one of everything else . . .
It seems to be the most reasonable???? TZ 's NASA garage.. Sure wish you lived up the street TZ. My excuse for a inch lb wrench. Made it years ago to set up 4x4 differentials. Still use it if I need accuracy?
Those are special jig & setup tools , one box to the right second from the bottom drawer . Do mine with a digital scale & weight .
