Harbor Freight lift table
Old Nov 28, 2011 | 07:21 AM
Gypsylady's Avatar
Gypsylady
-Moderator-"Wench with a Wrench and Queen of Quips"
I like mine. Works great for the Fatboy and the "CC".
Old Nov 28, 2011 | 07:55 AM
AtkRWC's Avatar
AtkRWC
I've had one for a few years. I'm less than happy with it. Ended up bolting it to the floor, as it seemed too unstable. Also it bleeds down after a day so use the lock bar. Changed the vise out for the HF Condor style chock. I don't plan on replacing the table but wish I had bought a better one to begin with.
Old Nov 28, 2011 | 10:52 AM
Big_Al47's Avatar
Big_Al47
Added to my Christmas list
Old Nov 29, 2011 | 02:09 AM
DZLDR's Avatar
DZLDR
here is what I did to my Harbor freight table lift.
THROW that POS front wheel vise away! get you a wheel chock and bolt it to the table top, then you can ride your bike (or push it) up on the table, into the chock, then just step off with no worries of it tipping over! Plenty of clearance for bagger fenders as well.
note: tie down straps should be used whenever rear tire is removed
Old Nov 29, 2011 | 05:38 AM
BillM's Avatar
BillM
I have the older version of this table. It does not have the drop-out for the rear tire. Otherwise it is the same. It is not the most stable thing but if there is two of you, you can load anything on it. I have used it quite a bit. Bought it used for $200. Still got the crappy chock on it, but, I always strap it down.
Old Nov 29, 2011 | 06:42 AM
cardboard's Avatar
cardboard
The problem with that wheel chock ain't gittin it in,its gittin it back out by yerself.
Old Nov 29, 2011 | 04:22 PM
BBStacker's Avatar
BBStacker
Isn't that what reverse is for? You know, you sit on it the OL pushes ya back.
Old Nov 29, 2011 | 04:23 PM
cardboard's Avatar
cardboard
Yea Right, my OL ain't that Big........
She hardly has her feet on the floorboards when they are in the down position.
She rides with the floorboards flipped in the UP position.
Old Nov 29, 2011 | 05:11 PM
HDmikie's Avatar
HDmikie
Default Harbor Freight Wheel Chock...........
I ordered a wheel chock from HB and it arrived today. If you look at the picture below you'll see that the chock appears to just be sitting on a driveway and isn't fastened or bolted down. But, when I read the assembly instructions they said it has to be bolted down to asphalt or a trailer bed.
My question: do any of you guys use this chock? If so, have any of you used it without bolting it down? I was hoping to just use it for oil changes and for winter storage to keep the bike upright to take up less space in the garage. Btw, I have a 2002 Fatboy. Don't mean to hijack the thread.......just thought this topic was similar. Thanks!
http://www.harborfreight.com/motorcy...ock-97841.html
Old Nov 29, 2011 | 05:20 PM
cardboard's Avatar
cardboard
My buddy got one of those, you can ride the bike up in it, but when you go to take it out.
Its very, very hard to git it out. YOu will be draggin the chock.
He wound mountin his to a 8' sheet of plywood.
