Harley warranty problem
Old Jan 5, 2012 | 07:30 PM
okieriverboy's Avatar
okieriverboy
1st Gear
Default Harley warranty problem
Hey guys. I need some advise on a problem with my dealers extended warranty I bought. My starter on my 08 streetglide sometimes kicks back and sounds like its about to come apart. I dosnt do it every time though. My warranty runs out in March and I took it in to the Dealer and they said that if they dont here the noise they cant look any further into it. From what ive been reading on the forum the compensator is probly bad or going bad but I cant get them to just take my word and pull the dam starter and look at it any advise on how I should handle this.
Old Jan 5, 2012 | 07:39 PM
Chunker's Avatar
Chunker
I would write up a detailed description of the problem, take the letter and the bike to the dealer and tell them if they won't fix it then sign the statement explaining why. That way if it comes apart later, you have it documented.
Old Jan 5, 2012 | 07:41 PM
Hollywood Ball's Avatar
Hollywood Ball
Pretty common issue. I had it on my Night Train. I had to replace my clutch hub bearing so my guy had everything torn apart. I'd told him about the horrible noise before and to check things out while he had it apart. There was no evidence of abnormal wear on the starter gear or compensator or anything else. Sure surprise me, because at times it sounds like the bike was falling apart inside.
Old Jan 5, 2012 | 08:30 PM
zukeeper's Avatar
zukeeper
kicking back is exactly what the engine is doing, its not the starters fault
Old Jan 5, 2012 | 08:37 PM
cdestuck's Avatar
cdestuck
Offer to pay for the teardown with agreement that if there is something wrong that your problem will then be fixed and covered under warranty. Your responsible for the first 50 anyhow.
Old Jan 5, 2012 | 09:23 PM
user 8373900's Avatar
user 8373900
An occasional kick back and cough through the air cleaner when starting is normal, there is nothing to be fixed.
Mark
Old Jan 5, 2012 | 10:52 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Yeah, buy a SE compensator and be done with it.
Old Jan 6, 2012 | 12:13 AM
Bluehighways's Avatar
Bluehighways
+1 Good Advice. Actually, as long as you have a Repair Order that describes your bike (VIN # is best), is dated, has the mileage of the bike and that spells out your complaint . . . even if the Dealer says they can not duplicate the intermittent problem that you describe . . . should something fail in the future, even after the expiration of the warranty, that can be linked to the complaint you made while the bike was under warranty . . . your A$$ is covered!
Old Jan 6, 2012 | 12:38 AM
hatchetman's Avatar
hatchetman
Bring your sled to a different licensed mechanic, tell him the story & ask his advise on the issue.
If he thinks your comp is hooped, Have him do the repair & pay him. Take your receipt with his memo stating the problem & solution & send that to warranty for reimbursement.
Hatch.
Old Jan 6, 2012 | 04:06 AM
dickey's Avatar
dickey
My Evo Softails did that all the time back in the day, especially when they were hot. My TCs never do, prolly 'cause I keep 'em on a battery tendery 24/7 & tighten the terminals & keep 'em Vaselined.
Biggest cause of that for a TC is low/old/bad battery, or connections not good.
