Oil usage
Old Feb 24, 2012 | 10:38 PM
TwiZted Biker's Avatar
TwiZted Biker
How thick it is isn't gonna make a difference in temp sorry your mechanic is still a bit green and too thick an oil is not good at low temps for twinkies . Evo & later engines are designed to use multi's dino or syn & stay with 20-50 unless you live out in 130 deg desert somewhere . You want to cool the oil only way is add an cooler and more oil volume with longer lines to radiate heat out as it passes through , your oil filter kinda does that for you now .
Old Feb 25, 2012 | 08:26 AM
mike5380's Avatar
mike5380
Stick with the synthetic multi viscosity oil. Straight 50 or 60 are too heavy to completely lubricate the tight spots in your motor.
Mike
Old Feb 25, 2012 | 08:32 AM
desertrideryz's Avatar
desertrideryz
I live and ride where it get to 115 degrees and i run synthetic 20w50 in my bike all summer just fine
Old Feb 25, 2012 | 08:36 AM
checkers's Avatar
checkers
I would use 20w50, or 50WT or 60WT, any synthetic or Dino oil would work the best. Be sure to change it annually or once a year, whichever comes first.. You can do a search and read the 1,000's of posts on this subject already done.
Old Feb 25, 2012 | 08:45 AM
Sefferdog's Avatar
Sefferdog
except I have to change mine 7-8 times a year as I ride it 35-40K a year.
Old Feb 25, 2012 | 01:01 PM
TwiZted Biker
I'm a dinosaur when it comes to the bike , oil gets changed at 2000 max on mine sometimes less . Not saying it's good or or bad but I've been getting a lot more life outa my old shovel engines than most believe you can so I'll stick with the habit , oil changes are cheaper than rebuilds .
Old Feb 25, 2012 | 09:42 PM
oct1949's Avatar
oct1949
Makes a big diff on what bike U have....older bikes did use the straight oils.
In my 96TC I use Mobil 1 V-twin 20-50 yr round.
cajun1957a
Shovelhead
Apr 15, 2015 07:35 PM
Rockrat
Oil Archive (no new posts)
18
May 28, 2014 03:54 PM
Andy_fxdwg
Oct 12, 2012 04:55 AM
Bflener
Apr 3, 2012 10:02 PM
vtxed
May 6, 2007 01:44 AM
