Neutral Lite Problems
Old Mar 13, 2012 | 10:19 PM
kodak86's Avatar
kodak86
Default Neutral Lite Problems
Hi
I am new here and my first post. Hope someone out there can help.
I own a 2007 Electric Glide Classic.
My Problem is that the green neutral lite (N) comes on when in gear. Has this happened to anyone else? Anybody fix it if so how ?
Thanks
Mark
Old Mar 14, 2012 | 01:34 AM
6 gun's Avatar
6 gun
I believe that I would seek an indy or a dealership to solve the problem.
Old Mar 14, 2012 | 03:03 AM
Potato_Potato's Avatar
Potato_Potato
Originally Posted by kodak86
Hi
Thanks
Mark
Welcome to the forum… Not saying that this is what is wrong but it is the first thing I’d try, as it is fairly easy to do.
The neutral switch (located on the tranny) can collect debris causing problems. Sometimes just taking it out, cleaning and replacing can correct it. If that didn’t work I’d buy a new switch and if that didn’t do it I’d take it to the dealer and say, ‘Hey there is something wrong with my neutral indicator ‘:-)
Tighten it to 120-180 in-lbs
Old Mar 14, 2012 | 08:56 AM
kodak86's Avatar
kodak86
Thanks I will try that and let you know the outcome
Old Mar 14, 2012 | 10:15 AM
jb13's Avatar
jb13
nothing to add except I thought this thread was about beer
Old Mar 14, 2012 | 01:25 PM
TheReprobate's Avatar
TheReprobate
Old Mar 14, 2012 | 01:27 PM
painey's Avatar
painey
Had same problem, took switch out and cleaned, problem solved
Old Mar 14, 2012 | 02:14 PM
oct1949's Avatar
oct1949
The switch can go bad,, sons 10 Street Glide had that issue last summer,, they tried to adjust it,, no Workie,, put in new switch doggie whopper and it fixed it... so maybe a new switch...
Old Mar 14, 2012 | 03:27 PM
BBStacker's Avatar
BBStacker
Is that like a thingamajig or dohickey? Replaced a whatchamacallit not to long ago.
Old Mar 14, 2012 | 11:11 PM
Gutman's Avatar
Gutman
Neutral switch is not magnetic like the speedo sensor, so no debris. HD come out with new neutral switch to remedy problem. Get the new switch with the "A" suffix on P/N and you will be good.
