Stall on 2003 Classic
Old Mar 22, 2012 | 05:04 PM
koukey's Avatar
koukey
Default Stall on 2003 Classic
We were out for a ride in very hot temps and lots of traffic when my 03 Electra Glide died on me. I pulled over and it started right away but I had to work the throttle to keep it going. I parked for approx.1.5 hrs and it started,no problem. I drove home, about 60 miles, at speeds between 60 and 70 mph,no problem. The engine light did come on at around 70 but did not stay on.Any suggestions would be appreciated as to what the problem might be,thanks.
Old Mar 22, 2012 | 05:13 PM
Bill03E's Avatar
Bill03E
They do this when they get hot, the fuel is burning as it enters the cylinder ,so it can't run well.
Old Mar 22, 2012 | 07:21 PM
koukey's Avatar
koukey
Default 03 stall
thanks for the tip.
Old Mar 22, 2012 | 07:52 PM
Hx3's Avatar
Hx3
If you still have the circuit breaker in front of the battery I would recommend replacing it with a 40 amp inline fuse. That solved the problem on my 03. Check the crimps and for corrosion on the terminals that attach to the circuit breaker also.
Old Mar 22, 2012 | 09:11 PM
BBStacker's Avatar
BBStacker
You failed to mention did it sputter or just die?
Sputter- Fuel
Just died - Electrical
Old Mar 22, 2012 | 09:15 PM
dickey's Avatar
dickey
You didn't mention if it was carb or EFI. Carb--might be vapor lock. EFI? Damfino!
sbergerson
Jul 29, 2014 11:22 AM
koukey
Aug 4, 2012 11:10 AM
leoks98
Jun 21, 2012 02:24 PM
tjs1053
Exhaust System Topics
Aug 1, 2009 10:03 PM
ozrider
Jun 4, 2007 12:07 PM
