HELP. Stuck on road. 2003 RKC Missing.
Old Jul 21, 2014 | 05:24 PM
sbergerson's Avatar
sbergerson
Default HELP. Stuck on road. 2003 RKC Missing.
Riding from Eastern Minnesota to Glacier Natl Park. We are in the middle of North Dakota and my 2003 Road King Classic with 71,000 miles starts missing like crazy.
I can get on the throttle hard and she accelerates good. When I let off and just maintain speed, it's missing and lurching like mad. The bike idles perfectly like normal. The engine light comes on when the bike is missing.
We are 90 miles from the closest dealer and can't find any Indy shops in Devils Lake, ND.
Maybe a bad connection? Already changed out the plugs which looked pretty normal.
ANY HELP WOULD BE APPRECIATED. I don't want to scrap this trip with my 74 year old dad.
Steve
Old Jul 21, 2014 | 06:22 PM
davemc's Avatar
davemc
Need to figure out if it is a fuel problem or an electrical problem. I would check the usual suspects first -- spark plug wires, then see if the battery connections are tight. I hope it's something simple and you get running soon.
Old Jul 21, 2014 | 06:28 PM
lp's Avatar
lp
Check for an intake leak.
Spray some WD-40 around the intake flanges where they meet the heads while the engine is running.
Hope you're back on the road soon.
lp
Old Jul 21, 2014 | 06:38 PM
SpiderPig's Avatar
SpiderPig
If it's an F.I. bike, and you have a power commander or any type of fuel management device installed. Unplug it and see if the problem persists.
Old Jul 21, 2014 | 07:04 PM
AlanStansbery's Avatar
AlanStansbery
What engine codes have you got stored?
alan
Old Jul 21, 2014 | 08:00 PM
sbergerson's Avatar
sbergerson
Thanks for the replies guys! I really appreciate it. I doubt it's a fuel problem, because when I get on the throttle, it goes like a raped ape. It's calling for max fuel.
I'll try the WD-40 trick tomorrow morning (raining like crazy now).
No power commander or fuel management system.
I don't know how to get the codes. Tried holding in trip button while powering up, but don't get PSSPt like newer bikes. I read somewhere that I could short out terminals 1 & 2 on the cable under the left cover, but mine has 4 connectors and I don't know which ones are 1 & 2. I tried all combinations but couldn't get engine light to flash.
Old Jul 21, 2014 | 08:17 PM
SpiderPig's Avatar
SpiderPig
This link might help you get the codes!
https://www.hdforums.com/forum/touri...dtc-codes.html
dawg's Avatar
dawg
How full is the gas tank when this happens? Pinhole in the hose maybe?
Old Jul 21, 2014 | 08:22 PM
skiddd's Avatar
skiddd
Start her up in the dark and look for a spark, could be a bad wire......
Old Jul 21, 2014 | 08:26 PM
sbergerson's Avatar
sbergerson
After it started missing, I filled the tank, added injector cleaner... No change.
Thanks for the link Spider.
Shorting pins 1 & 2... Can anyone tell me which of the 4 pins are 1&2? I can't read any markings.
