Engine Dressing
Old Mar 24, 2012 | 11:29 PM
BlazingC5's Avatar
BlazingC5
Default Engine Dressing
I washed my Softail for the first time today. After blow drying my bike, I decided to try a product that I use to detail my Vette engine. I sprayed it on the engine case and cylinders and the black came out looking like new with a dark satin shine. I've seen some threads about using S100 and Pig Snot, but I had this stuff readily available, so I gave it a try. I wasn't sure if anyone else had tried using this product from Chemical Guys.
http://www.chemicalguys.com/SPRAY_DR...ir_spray_1.htm
Old Mar 25, 2012 | 02:17 AM
Trailfndr's Avatar
Trailfndr
Please let us know how the stuff holds up to the heat of the engine. The website saysd its for plastic and rubber...does not say anything about metal areas or heat.
Old Mar 25, 2012 | 07:25 AM
1flhtk4me's Avatar
1flhtk4me
Seems like after some use,you would end with layers of baked on goo.
Old Mar 25, 2012 | 07:30 AM
TORQUEY's Avatar
TORQUEY
I have not tried it, but the Chemical guys make some great products for sure!
Old Mar 25, 2012 | 10:46 AM
BlazingC5's Avatar
BlazingC5
You guys are correct and I understand that it doesn't specifically say it can be used on metal. I have however sprayed it on my car around my engine for hard to reach areas for about 6 years and have not found any sludge or baked on goo. It sprays on and dries to the touch pretty quick, leaving no greasy residue behind. I simply wiped off any overspray on the chrome with a microfiber towel and it left nothing but a nice shine.
Pig Spit also shows a somewhat similar description. I figured it was worth a try.
Black On Black
Black leaves trim, engine parts, moldings, A/C vents and many other hard-to-reach areas black, shiny and protected.
Pig Spit
PIG SPITŽ ORIGINAL
Pig Spit improves the appearance of motors, transmissions, trim and components. Pig SpitŽ restores dull or faded rubber, tires, trim, vinyl, paint, chrome, and other surfaces.Brightens color and gives a clean finish. Makes old items look like new.
MysticPurple
General Topics/Tech Tips
Aug 24, 2017 08:02 AM
WARG
Jan 9, 2009 08:05 AM
gez45
Detailing
22
May 2, 2008 07:52 AM
MANCHU DOG7
Jan 6, 2008 02:14 PM
Ed45
Jul 15, 2006 02:58 AM
