another stupid oil question
Old Apr 9, 2012 | 06:42 PM
dyeates's Avatar
dyeates
Default another stupid oil question
Sooo. I change my oil, or have it changed, every 3k miles. But what about time? I'be only put 1k miles since last change, but was 6 months ago. Am going on a decent road trip soon, does the oil need changing again? Sorry for the rookie question. Thanks!
Old Apr 9, 2012 | 07:07 PM
hatchetman's Avatar
hatchetman
If my oil was clean but lets say 6 months has passed, I would consider the conditions that the bike sat in while it wasn't running. If I was concerned about moisture build up I would get it hot & dump it out. If that was not an issue, I would run it for 2000 miles the way it is!
Always best to swap out your oil before you put it to sleep in the winter because dirty oil has acids in it that will chew on your bearings where clean oil will not!
Hatch.
Old Apr 9, 2012 | 07:29 PM
PigInaBlanket's Avatar
PigInaBlanket
The best time is around noon.
Old Apr 9, 2012 | 07:32 PM
FNGonaRK's Avatar
FNGonaRK
The bike must be ridden a minimum of 3k miles every 6 months or the insides of the engine will rust. No oil out there can prevent that. Stop neglecting your bike.
piasspj's Avatar
piasspj
The official recommendation is at least once a year.
Old Apr 9, 2012 | 07:39 PM
lh4x4's Avatar
lh4x4
All manufactures and oil producers say change at one year.
My question is why change at 3K? HD says 5K. Mineral or syn is not worn out at 5K. 3K is a waste of money and a limited resource.
Old Apr 9, 2012 | 07:44 PM
dyeates's Avatar
dyeates
Wow! Thanks for the feedback! No moisture here, its AZ. Just a wimp for cold weather, 35-45 degrees is cold for us here. Lol! 09 SG with 16k on the clock. Running Syn3. Guess I'll just drive her!
Old Apr 9, 2012 | 11:19 PM
Other Sheep's Avatar
Other Sheep
Enjoy your driving.
Old Apr 9, 2012 | 11:53 PM
dickey's Avatar
dickey
Of course you are joking;right?
Let's not panic the OP.
Old Apr 10, 2012 | 01:38 PM
oct1949's Avatar
oct1949
same here, I change motor and Pri. oils at 4500 to 5k, Tranny I do 1@ yr witch is usually less than 10k
where U store the bike makes a big diff. I am glad I have a garage that stays 60-65* in the winter with almost no moisture.
