Iphone App vs Modulator Install
Old May 29, 2012 | 07:41 AM
Sauceman's Avatar
Sauceman
Originally Posted by FXDXTSport
The bike side of the opener is a transmitter that you wire into your bike and it is activiated by the high beam switch. Deosn't have anything to do with the high beam headlight directly. You could mount a separate switch if you wanted.
Seen, that makes more sense.
cheers
Old May 29, 2012 | 10:07 AM
strongwood's Avatar
strongwood
Originally Posted by fighthedude
What happens if someone pulls in your drive way and flashes there lights? Will it open for anyone or is it specific to your bike?
actually flashing the lights are not what opens the door
There is a small transmitter that you connect to the headlight wires that will energize the transmitter on your car / motorcycle
It comes with a receiver / garage door opener unit that you mount inside the garage
so when you flash your lights, it will transmit like a regular opener.
I have mine hooked to a recessed waterproof switch on the bike
the lights dont open the door
my only problem was when I had a HID light, it would vary the voltage enough when I started the bike that it would activate the door. that is why I moved it to a switch
soonerp
Milwaukee Eight (M8)
Apr 13, 2018 09:21 AM
Frankie-FLHXI
Vendor For Sale Classifieds
May 14, 2009 07:19 AM
YTHOG
Mar 31, 2007 12:42 PM
pauly711
Mar 23, 2007 01:15 AM
jd_underdog
Dec 28, 2006 12:02 PM
