Should I remove the baffles??
Old May 29, 2012 | 11:04 AM
Dyna-Ridin_23's Avatar
Dyna-Ridin_23
Default Should I remove the baffles??
Hey guys I have screaming eagle 2 slip ons on my 2011 dyna... Should I rip out the baffles?? I just wanna have it sound good until I do my stage 1 setup??? Thanks for ur help guys..
Old May 29, 2012 | 11:13 AM
Ghosteh's Avatar
Ghosteh
My SE pipes had the baffles punched when I bought it. I rode it a year like that, then switched them out for the stock pipes. It was WAY too loud to be comfortable. Loud in the city & droning on the highway.
You may like it though. Personally, I'd leave them as-is.
Old May 29, 2012 | 11:47 AM
RiverWolf's Avatar
RiverWolf
No. Do not. That is a metric thing. Loud is not a sound. Wait and save your money.
Old May 29, 2012 | 11:57 AM
schumacher's Avatar
schumacher
no, do it correctly and change them. motor's need backpressure
Old May 29, 2012 | 12:05 PM
TXHooligan's Avatar
TXHooligan
yanking out the baffles has never caused a problem in any of my bikes but like i've said before, i've never had fuel injected. i think the tuning might be ur only problem. as far as back pressure ur never gonna find a real answer. it's one of those topics that could hold an argument for days.
Old May 29, 2012 | 12:09 PM
VTTIMWHITE's Avatar
VTTIMWHITE
Don't do it. Louder does not always mean better performance and can actually hurt your air flow through the pipes. A lot. Read up on exhaust pulses and scavenging.
Too much airflow through the engine without adjusting the fuel/air mixture will result in a lean condition and that will destroy your engine, starting with the valve faces and heading out from there.
And depending on where you live, and your neighbor's definition of "obnoxious", you could get hassled by the po-lice.
Old May 29, 2012 | 12:24 PM
Geoff's Avatar
Geoff
Ask your neighbors if you should remove your baffles.
Old May 29, 2012 | 01:55 PM
NSCoyote's Avatar
NSCoyote
personally i would wait till you can cough up for a full system or better slip ons, if you really must have louder, look at some alternative baffles that will modify the sound note but still keep back pressure, BCT monsters or the QQ baffles, V&H also have baffles t hat would make it a bit louder for you
XL883LEB
Aug 22, 2011 01:24 PM
Slopneck
Feb 25, 2010 12:57 PM
giovex
May 22, 2008 02:23 PM
Rush
Jul 16, 2007 06:35 PM
brohrs
Jan 7, 2006 08:11 AM
