Remove Baffles & Re-Map?
Old Aug 21, 2011 | 02:49 PM
XL883LEB's Avatar
XL883LEB
5th Gear
Default Remove Baffles & Re-Map?
I have a 2011 883 Sportster Super Low w/Screamin Eagle Slash Cut slip-ons. Can I remove the baffles without remapping the ECM???
Old Aug 21, 2011 | 03:51 PM
Nubz's Avatar
Nubz
Old Aug 22, 2011 | 08:23 AM
XL50#674's Avatar
XL50#674
You can and not need a remap, but you should. I had SE slip on's with no baffles and it was very loud and did not sound as good as smaller open pipes like I have now. The slip on's are so big that it works like an echo chamber, but go ahead and pull the baffles and see what you think.
Old Aug 22, 2011 | 11:51 AM
XL883LEB's Avatar
XL883LEB
5th Gear
Thanx for the feedback!
Old Aug 22, 2011 | 01:24 PM
ShAwTWiN's Avatar
ShAwTWiN
Opening the exhausts (removing baffles) will result in a leaner A/F ratio... not good for your engine(hot). The reverse(like putting baffles in straight pipes) will be better, because running too rich will not cause any damage to your engine(cold)... only carbon build-up and waste of gas...
IMO, remap !
Dyna-Ridin_23
May 29, 2012 01:55 PM
vickers1
Oct 23, 2011 05:42 PM
Elie
Jul 18, 2011 03:40 AM
aldesi51
May 25, 2011 10:33 PM
Cupcake1973
Oct 9, 2010 10:19 AM
