Advice needed: high pitched whine from engine.
Old Jun 5, 2012 | 02:00 PM
99octane's Avatar
99octane
Default Advice needed: high pitched whine from engine.
I seem to hear some sort of high pitched whine from the engine. At a given moment today was quite loud, then it went almost away. Almost. Now is barely audible.
What the ****???
The bike is a '07 FXDC.
The chain tensioner comes to mind. Oil pump?
The bike is running flawlessly up to now...
I'm quite worried.
Old Jun 5, 2012 | 02:13 PM
Krazy8s's Avatar
Krazy8s
Sure it wasn't your passenger screaming ?
Seriously though, do you hear it under acceleration, decel, just cruising or all of the above?
Can you tell which side it is loudest?
I am sure people wanna help but some more info needed.
Oil pump is a possibility, but then so is your belt. Any work done on the bike before the whine started? If so, what?
Old Jun 5, 2012 | 02:45 PM
nytryder's Avatar
nytryder
Probably a bad lifter. They will exactly as you describe.
Old Jun 6, 2012 | 09:51 AM
99octane's Avatar
99octane
I hear it while idling at traffic lights. Dunno while riding, what with Khrome Werks exhaust...
Today wasn't there...
Old Jun 6, 2012 | 10:35 AM
69z28's Avatar
69z28
You didn't say milage but I would sure check cam chain tensioner.
Old Jun 6, 2012 | 10:38 AM
Cajun King's Avatar
Cajun King
I'll second cam chain tensioner. I had a whine in my road king last month and 1 tensioner was completely gone.
Old Jun 6, 2012 | 10:53 AM
oct1949's Avatar
oct1949
Its a 07 guys,, Unless he's got over 75k on his bike I highly doubt that its the cam tennsioners..
Old Jun 6, 2012 | 11:04 AM
rdb1976's Avatar
rdb1976
Try upshifting...
J/K
Old Jun 6, 2012 | 01:32 PM
dickey's Avatar
dickey
You ride around a lot with a Brooklyn guidette on the back?
Old Jun 6, 2012 | 02:04 PM
Hollywood Ball's Avatar
Hollywood Ball
Had a similar problem on my 09 train at about 24K... Came from the primary side. Could only really hear it at idle, came and went with pulling in clutch.
Ending up being the clutch hub bearing. Replaced another bearing while it was apart, mate. The inner primary bearing? Can't remember.
