Programming new proximity key fob
Old 06-27-2012, 01:46 PM
hivoltg's Avatar
hivoltg
hivoltg is offline
Default Programming new proximity key fob
I bought my bike used and it only came with one key fob. A friend of mine just gave me one, but how do I make it work with my bike?
Old 06-27-2012, 01:50 PM
TheRooster's Avatar
TheRooster
TheRooster is offline
Didn't get a manual when you bought it?
Old 06-27-2012, 06:31 PM
Potato_Potato's Avatar
Potato_Potato
Potato_Potato is offline
If I recall the dealer has to do it using the DT.
Old 06-27-2012, 07:11 PM
hawwk's Avatar
hawwk
hawwk is offline
Potato Potato is right. The dealer has to progam it and make sure you have all the fobs with you when programing
Chief1991 (04-03-2022)
Old 06-27-2012, 11:26 PM
azblackbird's Avatar
azblackbird
azblackbird is offline
Ditto... plus while they're programming your FOBs, have them set the manual code to a number you can easily remember, just in case you lose your FOB, and have to start your bike manually using the code procedure.
Old 06-28-2012, 05:16 AM
ckal704's Avatar
ckal704
ckal704 is offline
I lost one of mine and the spare was verified "bad" by a local dealer. New one cost $40. Not bad. I had already programmed a code so I could start the bike, but entering a code is a bit of a pain if you have to do it all the time.
Old 06-28-2012, 05:23 AM
TheGeek's Avatar
TheGeek
TheGeek is offline
You don't need to go to the dealer....http://www.ehow.com/how_7486894_prog...ob-harley.html
Old 06-28-2012, 05:29 AM
Potato_Potato
That isn’t for the proximity remotes because one of the steps involves pressing the button on the Fob.
Hold down the button on the remote that you wish to program to the transceiver until two flashes are seen coming from the signal and indicator lights on your motorcycle. You should receive this confirmation within 10 to 25 seconds. Repeat for any additional buttons at this time as well.
Old 06-28-2012, 01:19 PM
hivoltg's Avatar
hivoltg
hivoltg is offline
Obviously not, hence the topic I started here. Thanks for the helpful input though
Looks like I'll be heading to the dealer
Thanks guys
Malleck
10-17-2022 07:51 PM
fxesuperglide77
03-06-2012 06:15 AM
wmfuller
05-03-2010 01:27 AM
rwj4709
10-31-2008 10:15 AM
jacktana
10-06-2007 10:14 PM
Quick Reply: Programming new proximity key fob
