Sportster re-engineering?
Old Jul 4, 2012 | 08:47 AM
DPete's Avatar
DPete
I had an 07' it would run circles around my SG, only improvement I suggest would be suspension, longer travel forks and better shocks
Old Jul 4, 2012 | 09:12 AM
not_so_newb's Avatar
not_so_newb
they tried re-engineering the Sportster , it was called a Buell . didn't sell enough so they shut it down . don't expect anything radical from HD , the Buell and the Vrod show they can't figure out how to sell new stuff so they're sticking with what they know (and we all like)
Old Jul 4, 2012 | 10:50 AM
schumacher's Avatar
schumacher
I think the sportster builder thing is enough re-engineering for now
Old Jul 4, 2012 | 12:15 PM
Nubz's Avatar
Nubz
Originally Posted by Uncle G.
Beginning in '54, with the KH model, the Sportster had a "trap door" in the left side case which allowed the transmission to be easily removed from the bike for repair without having to pull the engine, pull the jugs and split the cases. That was a lifesaver on my '89 Sporty, as I had the transmission pulled three times while I owned it due to faulty shift cam followers that would distort when overheated, causing the shift mechanism to hang up.
In '04, when Harley redesigned the Sporty for rubber mounts, they omitted the trap door, and thus, the transmission can no longer be accessed without pulling the motor and splitting the cases. This means that should the transmission fail, it's very likely that repairing it may cost more than the bike is worth. When a repair costs more than the item is worth, that implies that the item is a "throwaway" or disposable item. To be fair, the five speed is much more durable than my old four-speed, but things can still go wrong on occasion.
Don't get me wrong, I love Sportsters, but, by making them harder and more expensive to repair, I feel Harley is moving inevitably toward the "throwaway" business model. Serviceability and repairability are major reasons I own and ride Harley-Davidsons.
Makes sense why I see so many 03 sometimes now
Old Jul 4, 2012 | 02:54 PM
88xlh1200's Avatar
88xlh1200
Unfortunately, IMO, the Sportster ended when it went rubber mounted. It gained weight (almost 75lbs more than my '88), and most of them now have barely any better lean angles than a lot of the Big Twins. Throw in the missing trap door as mentioned previously and the Sportster has lost most of it's "Sport".
Don't misunderstand me, the Sportster line still has some very nice bikes which a lot of people enjoy. I still entertain the notion of buying a newer one from time to time.
But if I were to want to build a more performance oriented Sportster, I'd go with a rigid mounted Evo from 86 to 03. Build the motor, upgrade the trans, put some good shocks and forks on it, and strip off a few items to bring the weight down to around 450lbs. THAT would be a fun bike to blast around on for a Harley, and it has already been done by many people.
A rubber mount would need about 20% more power to keep up with the 450lb bike.
J
Old Jul 4, 2012 | 03:12 PM
Shredding rubber's Avatar
Shredding rubber
The sportster is fine the way it is. It's selling just fine.
Now,to the poster trashing the twin cams,you must not have one. My 96,now 106 has been reliable to a fault. The engine runs like a scalded cheetah and I haven't had a single engine problem.
As a matter of fact the only issue I've had with my twin cam street bob is the cheap *** front wheel bearings,other than that the bike is as reliable as my 06 v-star was. Not even so much as a hiccup.
Stay in the stone age.
Old Jul 4, 2012 | 03:51 PM
Shredding rubber
Old Jul 4, 2012 | 04:36 PM
Nubz's Avatar
Nubz
Originally Posted by KBFXDLI
I think the Sportster engine is the most reliable engine HD makes. I would like to see them upsize it to a 1600cc and add a 6 speed and larger frame and replace the Dyna line. I would take that engine design over a TC any day.
LoL think about what you just said
Just buy a dyna and be done with it instead
Razorback Rob
Dec 20, 2021 01:46 PM
DCOURTS
Mar 21, 2010 12:47 PM
cpiad
Oct 17, 2009 11:33 PM
ripto
Jun 18, 2008 06:07 AM
Tdog1
May 16, 2008 05:59 AM
