Too much gas in tank - now what?
Old Jul 24, 2012 | 10:24 PM
kkiley's Avatar
kkiley
I've filled mine a hundred times or more right to the brim, never had an issue. There's an overflow at the front top of the tank so that should have handled the excess. And just where did you put your gas cap while you were filling?
Old Jul 24, 2012 | 10:28 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Originally Posted by JonW
So what would you have done? Any way to easily solve this problem with no tools at hand?
Kept riding another 15-20 miles. Then cleaned it off when I got home. Gas will come right off with simple green and warm water.
Old Jul 24, 2012 | 10:37 PM
Pagman's Avatar
Pagman
Whatever you smoke, whether it's green, legal, or brown... I would hold off a bit before lighting up!
Old Jul 24, 2012 | 10:45 PM
Wooly's Springer's Avatar
Wooly's Springer
6th Gear
Seriously.... if you can't hold a gas pump long enough to pump 5 gallons of gas, something is wrong. I never fill mine to the top, my *** will be sore before my tank is empty lol. If I were to ever spill gas on my paint, I would PAT it dry with one of those blue papertowls vs rubbing and scratching the paint.
Old Jul 24, 2012 | 11:41 PM
ackman1968's Avatar
ackman1968
Be glad you have clear coat, I was bored and repainted mine but skipped the clear for that denim look. Turns out it was a bad idea (knew it going in but though what the hell). Although I had a good record of no spills once I did the paint I spilled regularly and had some killer effects in the paint!
Old Jul 24, 2012 | 11:48 PM
Ragtop's Avatar
Ragtop
You need the McCuff!
http://www.mccuff.com/
That must be the most useless invention I have ever seen.
Mikey spilled gas all over when filling some poor guys bikes to show how good
it worked.
I can't believe people actually buy those things!
Old Jul 25, 2012 | 12:09 AM
SR90's Avatar
SR90
Originally Posted by lh4x4
I'm trying to get my head around filling a tank to over full? Over full is when it runs onto the ground while you keep filling. At the very tip top if full and there will still be a pocket of air in the tank.
Put the cap on and ride. A quart of gas will be gone in about 10 miles.
You made a mountain out of a mole hill.
+1 oops put a bit too much in. Try rocking it back and forth to let the air in the pocket out.
Old Jul 25, 2012 | 12:42 AM
zeus33's Avatar
zeus33
Old Jul 25, 2012 | 12:45 AM
j1mmy's Avatar
j1mmy
go for a 20 mile ride, it wont be over full anymore.
Old Jul 25, 2012 | 04:08 AM
Roadie53's Avatar
Roadie53
Originally Posted by Iron Butt Springer
To ask a question like this i doubt if the OP rides more than 10 miles a month... Come on you cant figure out how to get rid of 1/2 cup of gas.... Do you have the box your bike came in?
