Too much gas in tank - now what?
Does it take any longer to just stand there and squeeze the nozzle as your fueling? Ive even heard rumors that you can even watch the fuel level rise up as your pumping... What a novel Ff'n idea
Auto shutoff while fueling your bike
* Where do you put your gas cap?
* What do you do if you over fill the tank?
* Tire shine questions...etc..etc
WTF? I guess it just isn't texting cagers folks need to worry about.
I just got back from Canada and a couple friends came with (I usually travel alone) - we stopped at a gas station and for the first time I set the lever and was talking to them (I was right next to the tank) when the gas started pouring out of the tank, about a half gallon. I guess I can't talk and pour gas at the same time.
Luckily nothing caught fire. I've never had a pump NOT stop, whether I was holding the lever or not.
Normally I pour 4 gallons and then watch through the filler hole until full.
Actually the OP didn't say he locked the pump handle on,,
He did say it didn't click off when the gas filled the nozzle..
I' ve had that to happen to me also and the pump handle wouldn't shut off one time, gas going everywhere..
Looking like a water fountain I ended up just throwing the handle to the ground on the other side of the pumps and it finally shut off..
I wasn't to happy, well really pi$$ed,, I went inside and the kid behind the counter said, "OH yeah,, We had a DO NOT USE" sign on that pump,,, BUT it blew off a while ago... I am thinking don't someone inside have to clear the pump before it starts...duh..
And Yeah I prepaid with credit card so I also paid for the extra gallon or so that came out. I did fill out some form for refund but that didn't happen either. Well least not since the yr ago since it happened..
