BAD regulators ??
Old Jan 18, 2007 | 09:41 PM
madjack's Avatar
madjack
Stage I
Default BAD regulators ??
2005 classic w/40,000 and gone through 5 regulators...what gives?
HD says they don't have this problem---need help, warinty runs out soon.[:@]
Old Jan 18, 2007 | 09:57 PM
Stogie's Avatar
Stogie
Default RE: BAD regulators ??
Sorry,
I've got a 2005 RKC and have had no problems....
Good Luck.
Stogie
Old Jan 18, 2007 | 10:02 PM
Tinkermc's Avatar
Tinkermc
madjack maybe you did not understand you have a problem, not HD. I think in most states you would qualify for relief under the lemon law.
Being that the same repair was made three times and continues to fail.
Old Jan 18, 2007 | 10:22 PM
pococj's Avatar
pococj
Are you taking it back to the same dealer? Might be time to try another one.
What has the dealer told you the problem is? If all they're doing is replacing regulators, and they've gone through 5 of 'em, they're not even trying to fix the problem.
Have you contacted HD customer service to see if they can do anything?
Need more info!
Old Jan 18, 2007 | 10:55 PM
2005UltraNC's Avatar
2005UltraNC
Have an 05 Ultra - went through one regulator. They also said the connection (sort of under the right floor board) was bad as well. Just guessing, I bet you have some other problem than the regulator.
Old Jan 18, 2007 | 11:48 PM
Bryan TTM's Avatar
Bryan TTM
yep...your dealer is too lazy to find the reason it burns regs...go to another one
Old Jan 19, 2007 | 06:30 PM
pittguy's Avatar
pittguy
I wouldnt lay this in dealers lap unless its something else taking reg out.These things are subjected to the worse conditions for an electrical unit,Heat ,water,vibration.owner abuse.Some ompans such as accel use to offer better warrantys on these,still may.Have your charging system checked first.
Old Jan 19, 2007 | 11:38 PM
rrockefe's Avatar
rrockefe
I have an 06 Ultra and the regulator failed in about 9 months.
Danall
Apr 19, 2018 02:13 PM
glide05
Exhaust System Topics
Aug 15, 2016 03:44 PM
mulch63
Jun 17, 2010 05:36 AM
MidnitEvil
Oct 9, 2009 11:12 PM
dspencer
Dec 3, 2008 06:29 PM
