I replaced the battery in my 05 road king in early August. Hooked up a Global 1.25 Amp Battery Charger. The charger won't go to green, stays on steady orange. The battery voltage is 14v. The charger output is .89v.
Is this normal output for the charger? If it is what should I check next? The battery cables were cleaned when the battery was installed.
I replaced the battery in my 05 road king in early August. Hooked up a Global 1.25 Amp Battery Charger. The charger won't go to green, stays on steady orange. The battery car Parts Wholesale voltage is 14v. The output is .89v.
Thanks for your help,
Larry
I have the same problem, can you tell me if it is the amp output?
It took my CTek multi us 3300 almost 24 hours to go to green last week. Battery is right at 1 year old and bike had been down for about 3 weeks before i hooked the Ctek up.
