Pull her out, start err-up, close garage door, put helmet on, put pegs down and give the old bitty's something to complain about for the rest of the day.
The twin cams don’t need the warm up like the older motors because of the o-ring at the base of the cylinders. This is where the problem is with dissimilar metals being cold.
And this is where you usually get a oil leak because you failed to warm the motor up.
And why you warm the bike up.
Start it up put it in gear, let it idle as I run down the drive and dirt road. Get on it in about two miles if it is real cold out.
If you ride a evo, you need to be much more careful. If you ever have them rebuilt then have the cylinders cut for a o-ring. Most reputable machinists know to do this.
