Do you shift without the clutch?
Old Oct 25, 2012 | 10:32 PM
  #51
gtnot's Avatar
gtnot
I have a Pingel electric, as stated it kills the ignition during the shift. I use the clutch for the 1-2 and 2-3 shifts, then forget the clutch from there. Always use the clutch downshifting.
Old Oct 25, 2012 | 10:41 PM
  #52
bigdaddy33's Avatar
bigdaddy33
Yeah, sometimes. Haven't had any problems.
Old Oct 26, 2012 | 04:54 AM
  #53
roadking2000's Avatar
roadking2000
Apparently, there are some that have no real reason to do it, but do. I have to wonder why anyone would want to. On down the line, those same guys will be posting about how their tranny failed after "only" x amount of miles. I guess if you can dream up some idiotic way to do anything, someone is already doing it on a regular basis.
Old Oct 26, 2012 | 06:55 AM
  #54
dog155's Avatar
dog155
Same here with trucks and tried once with Harley it did not work good at all.Our 06 bike had the trans gears back cut making power shifting an absolute joy.
Old Oct 26, 2012 | 07:23 AM
  #55
Sauceman's Avatar
Sauceman
You realize back-cutting the gear cogs makes them hard to jump out of gear, not easier to go into gear.
cheers
Old Oct 26, 2012 | 07:57 AM
  #56
mjrfd99's Avatar
mjrfd99
Originally Posted by Oldsarge29
The trans on the scooter is a completely different animal from the trucks that I have driven. There is no way to hesitate between the gears. I have never shifted the scooter without the clutch but I know a guy that claims he does it all the time. I think he is full of chidt.
HD trans DON"T like it. Busa couldn't care less, let off the gas a little and click next gear.
Rode home clutch cableless a couple times over the years ,you can do it with a HD but from the noise the HD trans is NOT happy clutchless. ie;grinding clunking
PS big trucks have a neutral between every gear thats why ya can go clutchless except for takeoff.
Old Oct 26, 2012 | 08:09 AM
  #57
patrickd's Avatar
patrickd
Originally Posted by Harleycruiser
Patrick you can tell by the sound of the motor, when it would match the speed of the next gear. Plus like I said, the gears slide on the main shaft, the dogs keep the gears from sliding when they are under load, as soon as the load is released the gear can slide.
And just a gentle pull on the shifter, otherwise you will force the shift.
This is my personal opinion but I don’t think it is any worse on the trans than when you clunk it into first gear when it is cold.
I'm trying to figure this out still. Obviously I'm not understanding something. What does the speed of the next gear sound like?
You know forget I asked. No offense meant. 'll just keep using the clutch. Thanks anyway.
Old Oct 26, 2012 | 09:49 AM
  #58
heybaylor's Avatar
heybaylor
Its obvious from the post's that more of you spend a lot more time polishing the bikes than working on them.
A lot of b.s statements made on this thread.
The transmission is a CONSTANT MESH/ Dog shifting /drum channeled shifting forks. shift lever justs rotates the drum.
drum moves forks that move the dogs.
no way to grind a gear , or chip teeth . sound you hear on a bad shift is the dogs hitting on the slot in the gear. (shift was too slow)
and there is a Neutral between each gear , just not detented
all the dog needs is a little slack to move out of one gear to the next.
dogs are two sided little thingys between the free gears.
the dog locks the counter shaft to the selected gear.
that can be accomplished with a clutch, or ,or ,or
blip the throttle ..gear is just as happy to change.
those of you that dont understand , or have a feel for "blip"
then by all means use the clutch.
lay off the "urban legends" / what your buddy told ya
Old Oct 26, 2012 | 02:32 PM
  #59
Harleycruiser's Avatar
Harleycruiser
Give this man the silver star. Someone who actually knows what he is talking about.
Old Oct 26, 2012 | 04:22 PM
  #60
Grof's Avatar
Grof
handlebar has on the left side a lever called clutch and his function is to switch between gears. It is stupid to suggest someone to shift without it.
