Engine swap
Old Nov 7, 2012 | 05:40 PM
DannyWest's Avatar
DannyWest
Stage III
Default Engine swap
I have a 2005 CVO Fatboy with a weak bottom end that has over 50K miles on it. I have a 2010 SE 110 B motor that only has 5K on it but of course the transmissions are different as far as the mating at the primary but I'm wondering if I can put a 2008 6 speed in the frame to mate up to the late model engine using a complete late model primary set up.
Old Nov 7, 2012 | 06:08 PM
jmorganroadglide's Avatar
jmorganroadglide
Big Kahuna HDF Member
I watching this because I thought the difference in the frames would prevent this engine swap.
Old Nov 7, 2012 | 06:42 PM
bwana1's Avatar
bwana1
These are Softail frames, they haven't changed. As long as you have a 6 spd vs the original 5 spd it should match up.
Bwana
Old Nov 9, 2012 | 02:27 PM
DannyWest's Avatar
DannyWest
Stage III
Research is telling me that the 2010 engine & 08 transmission will bolt into the 05 frame & requires the 07 & later softail primary drive & starter
Old Nov 9, 2012 | 06:42 PM
oct1949's Avatar
oct1949
Why don't U take an hr of Ur time and talk to U local Hd dealer Wrench.
U probably will get the correct answer instead of what most of us in here will only guess at.
Old Nov 9, 2012 | 06:52 PM
1flhtk4me's Avatar
1flhtk4me
Why do you think the bottom end is weak?
cwbarg
Jan 30, 2016 01:15 PM
BungoBill
EVO
Oct 29, 2013 05:15 PM
funkadellic69
Mar 21, 2011 03:55 PM
therealPIKO
EVO
Jan 1, 2009 11:40 AM
jdaniels
General Topics/Tech Tips
Mar 18, 2008 03:23 PM
