Lowering kits
Old Dec 3, 2012 | 06:26 PM
midnight blue's Avatar
midnight blue
Stage II
Default Lowering kits
Has anyone lowered a 2013 street glide with rear lowering blocks have lowered front end with new springs did not seem to lower bike
Old Dec 4, 2012 | 07:49 PM
hat's Avatar
hat
Yes. I did like you and lowered the front of my wife's street glide frist and then lowered the rear with the LA Choppers lowering blocks. When you think about it if you lowered the front 1 inch at the seat you you have probably only lowered it about a half an inch based on the geometries of the angle.
Old Dec 4, 2012 | 08:12 PM
xracer110's Avatar
xracer110
swap out the shocks, it will drop then
Old Dec 7, 2012 | 07:10 PM
midnight blue
Stage II
yes this is my wife's bike i ask as it does not seem to be much clearance between the wider tire on a newer model and the fender plus concern over exhaust to ground clearance lowering blocks do not list as compatable for 2013 model
Old Dec 7, 2012 | 09:35 PM
hat's Avatar
hat
The 2012 and 2013 are the same. I run about 15# of air in the shocks and no issues with bottoming out or ride quality. The ground clearance is fine you will scrape the boards well before the exhaust
SnoRider
Dec 27, 2015 07:47 PM
str hot rod
May 18, 2015 11:29 AM
str hot rod
General Topics/Tech Tips
Dec 4, 2014 04:09 PM
AngryAmish1163
Jul 8, 2010 07:18 PM
Stone1
Sep 16, 2009 08:38 AM
