ceramic coating or exhaust wrap? or both?
Old Dec 7, 2012 | 05:42 PM
DYNAM1C's Avatar
DYNAM1C
Default ceramic coating or exhaust wrap? or both?
Cant seem to make up my mind between getting a set of thunderheaders or the V&H big radius 2-2... Ive read good things about both and im not leaning towards one more than the other...
So ive narrowed down the deciding factor to looks and price...
The V&H comes with the ceramic coating so i would probably leave it as is... i think its a really cool lookin set of pipes... but i also think wrapped thunderheaders look badass too... ive heard thunderheader has some issues with quality, so if i were to get the t-headers id probably wanna get them coated.
Would wrapping the pipes over ceramic coating be detrimental in any way? Ive searched through the forum a bit and i can find threads about ceramic coating or wrapping, but nothing about what would happen if i did BOTH on top of each other.
Thanks in advance fellas.
Old Dec 7, 2012 | 06:35 PM
Spork's Avatar
Spork
A few of years ago I went through a couple of VH ceramic coated pipes.
The first set lasted about 6 months before they rusted all to hell. The second set lasted 11 Days (yes days) before the ceramic flaked off and exposed bare metal.
After the second set of VH I had TH put on and have not had a problem.
Now, if you go with VH ceramic your millage may vary (they may have fixed them) however you might consider chrome VH and get heat shields. Good luck with whatever you decide.
Old Dec 7, 2012 | 06:37 PM
back again's Avatar
back again
If you wrap them have the inside of the pipes coated. Jet Hot has served me well over the years between car,truck and bike headers.
chuck3049's Avatar
chuck3049
check out dragos headers coated inside and out comes with 2 year warr.
Old Dec 7, 2012 | 06:51 PM
Adrian Thompson's Avatar
Adrian Thompson
I've heard ceramic coating is better, but I think wrap looks better. I wrapped mine and used high temp silicone paint on the wrap to keep it element-resistent and to prevent fraying and maintain a deeper color.
Old Dec 7, 2012 | 08:11 PM
DYNAM1C's Avatar
DYNAM1C
So dont get the outside of the pipes coated? hmmm... didnt think about that.. Only reason i want the wraps is for the looks... I suppose I can get away with just coating the inside and wrapping the outside...
Old Dec 7, 2012 | 08:15 PM
DYNAM1C's Avatar
DYNAM1C
Also, whats a good wrap that you gents would suggest? black bike, black pipes, so black wrap obviously...
Old Dec 7, 2012 | 10:16 PM
Sconnie's Avatar
Sconnie
I used Thermo Tec, the stuff they sell at AutoZone. Great stuff, used what was left of the spray to paint my Cycle Shacks too and it was a lot better than the VHT I used originally.
Old Dec 10, 2012 | 12:25 PM
DYNAM1C's Avatar
DYNAM1C
Originally Posted by CCPcoatings.com
It sounds like your decision is based primarily on looks, so you'll have make final call there. But no worries on function either way. The wrapped pipes will be as effective as the Ceramic Coated pipes. If you plan to wrap your pipes though, Ceramic Coating them first is the BEST way to go about it.
Wrapping uncoated pipes is typically a death sentence for them. The reason for this is that moisture gets trapped in the wrap so the pipes end up corroding fairly quickly. Worse yet, when guys wrap their pipes they rarely inspect them so the damage is usually pretty bad by the time they realize it.
The only problem I can foresee, with wrapping mass produced Ceramic Coated pipes is that most are not profiled during the coating process, i.e. they are not blasted. So the coating doesn't really have much to bite into which means they tend to peel or flake prematurely. If you choose to wrap these pipes I would make a point to inspect them every 6 months or so to reduce any potential damage.
Judging from your forum name, im going to assume you know what you are talking about. Thanks for the info, I think I'm going to go with the thunderheaders and have em cleaned/coated and wrap em up as well, although i think it will end up costing more in the end compared to buying the V&H...
Old Dec 10, 2012 | 04:43 PM
DYNAM1C's Avatar
DYNAM1C
Does the Thunder header set up look like these?
my bike is black. not sure what you mean by do they look like the ones u posted... im assuming you're talking about the finish, but i havent actually ordered them yet, but they will be black.
