Throttle by wire??
Old Feb 5, 2013 | 06:49 PM
redglider1980's Avatar
redglider1980
Default Throttle by wire??
Any one ever solder there tbw.? Instead of using the connectors?
Old Feb 5, 2013 | 06:52 PM
Lundee's Avatar
Lundee
Yup. No issues.
Old Feb 5, 2013 | 08:23 PM
Northbound Southerner's Avatar
I replied in your other thread. It usually works but I know of folks having issues. If it were me, I would just buy the screaming eagle extended TBW sensor. Then you won't have to worry about having to pull it if it doesn't work. Those Yaffee bars are a huge PITA. You only want to do them once if possible...Check all of your connections before you pull your wires and then check them again...
Old Feb 6, 2013 | 12:27 AM
DZLDR's Avatar
DZLDR
previous poster is correct in saying those Yaffe bars are a PITA!! Having said that, I just put a set on my buddys 2012 street glide and I ended up just cutting the wires (all six) about three inches from the twist grip sensor and ran all new wires (18) in the right tube assembly. I connected them into the upper wires with red heat shrink butt connectors I got from Orileys auto parts. I used them because I kept pulling the soldered wire extenders apart when pulling wiring through the tubes. (did I mention Yaffe bars are a PITA) When everything was all put back together, fired right up and not one single problem with anything. It worked for me, thats my 2cents.
clap
Apr 5, 2017 08:07 PM
trace2008
Jun 16, 2015 10:02 PM
ms_weasel
Electrical/Lighting/Alarm
Dec 11, 2011 11:39 AM
gtrplyr
Jul 30, 2010 11:00 AM
scuba1954
Mar 10, 2010 06:27 PM
