Foot throttle?
Old Mar 4, 2013 | 01:39 PM
  #31
brenn's Avatar
brenn
Personally, I'd suspect her problem is at least partly lack of hand strength and I'd get her a $10 throttle rocker to try before I started getting foot throttle and making changes that require her to relearn how to ride a motorcycle.
Old Mar 4, 2013 | 03:23 PM
  #32
zeus33's Avatar
zeus33
Big Kahuna HDF Member
Originally Posted by pork
Thanks, zeus33. The first of the three images you originally sent was the one to which I referred above, which I found on Google. It looks really nice but is not commercially available. I am trying to contact the guy who built it for his Sportster.
I had also found the second one on google, which is the first one now shown in your post, but I believe it is an electric speed control.
The third one, the Hot Foot, might work, but I cannot tell much about it from the picture. I will google the product name and see what I can find out.
HI pork,
I had this posted originally but deleted it because it doesn't look like it would work on a bike...
By the way, I googled "motorcycle foot throttle" then clicked on the "images" link on the google page. I like searching by image, I have good luck with that.
Good luck in your quest.
Old Mar 4, 2013 | 09:45 PM
  #33
pork's Avatar
pork
As I have said several times above, she has tried two different throttle rockers, which we still have, but they have no effect on the numbness. If you install the device as required, you still have a bend in your wrist, and her hand still gets numb. Even if you install it rotated too far forward for safety, her hand still gets numb from holding it in a set position for too long.
She also experienced once or twice when the throttle rocker hung up on her glove or jacket sleeve and created quite a problem.
Also, as I have said, hand strength is not the problem. Several doctors have examined her and concluded that her hand strength is at least normal. She does extensive weight machine workouts three times a week. I'm not sure why you would think that numbness would result from a lack of hand strength.
Anyway, thanks for giving it some thought.
Old Mar 4, 2013 | 10:04 PM
  #34
pork's Avatar
pork
Originally Posted by zeus33
HI pork,
Right, I got mixed up on your images in my last post to you. Anyway, I had already found the aluminum billet device that somebody built for his Sportster and am now trying to locate him. I had also seen the one you deleted but didn't think it would be feasible. I have now found the Hot Foot throttle that you found for me, but hope I can find something more easily adapted to a bike. It is a boat throttle that uses a single cable, so we would have to be willing to dispense with the return cable. It also looks quite large for installing on a bike, and of course you would have to remove the toe clip for safety reasons.
Thanks again for your help. Really hope I can find a way to duplicate the aluminum billet device. As I mentioned above, she has no bike right now, so we would have to get a bike and take it to a fabricator to get the throttle made up, because some trial and error would probably be required. Wife is skeptical and doesn't really want to spend money on a bike without knowing we can make it work. That is why a purpose-built commercially available device would be really helpful, but it doesn't look like one is available.
Thanks again to everyone for your thoughts and suggestions.
Old Mar 5, 2013 | 01:14 AM
  #35
TRacer's Avatar
TRacer
Pork,
Try giving this guy a call as he might have some ideas or be able to assist:
https://foursquare.com/v/originals-b...b0b95600f3c3c1
His address and phone number are listed in the link.
I have stopped by his shop a couple of times as it is on my way to work and his fabrication work is outstanding. His personal bike is an old K-Model rigid Sportster he built that features a custom right side hand clutch/jockey shift and left foot throttle that I thought was the clutch pedal at first, until I saw that the single cable hooked to it was far too dainty to handle clutching duties. The foot throttle is brass and looks like something you would see on an old street rod. When I spoke to him about it he said he'd be reluctant to build something like that again, but given the medical reasoning you've outlined and the fact it would be going on a Sporty trike perhaps he would rethink it.
I had hand surgery on my dominant right hand back in 2010 which resulted in a fair amount of scar tissue and now I can't close my hand all the way. Perhaps someone else has already suggested it, but I had a billet RH throttle bracket drilled & tapped so I could remount the throttle on the LH side like an old-style Indian and it works like a charm; I say this as from your posts it sounds like your wife's wrist issue is on her right side only (?) I have one of Jordan's business cards around my home somewhere too as I am interested in having him fabricate a RH tank shift for the Sporty in my avatar so that I'm not shifting and throttling with the same hand as I've been doing since the surgery (my bike has an FLH police-style tank shift and LaBriola foot clutch pedal I put on in 2008 after injuring my left elbow.)
Anyway, I hope this helps.
Old Mar 5, 2013 | 07:37 AM
  #36
hdbob2006's Avatar
hdbob2006
The original internal throttle on Harleys would not return to idle,by spring pressure. You had to twist the grip to accelerate or decelerate.[throttle grip stayed wherever you set it] I wonder if the modern aftermarket internal throttles work that way?
[ A spiral track inside the handle bar pulled the cable up,or pushed it back.]
BTW-that "hotfoot" is for boats.. It seems to me that a foot throttle would be a real problem taking off from a dead stop,or inching slowly in traffic.
Old Mar 5, 2013 | 09:05 AM
  #37
pork's Avatar
pork
Thanks, TRacer. I will contact him to see what info he has. I would probably be reluctant to try to convince somebody to build something that he doesn't want to, but maybe he will have some helpful info.
Actually, Sue's left hand has a cramping problem, while the right hand goes numb. That's why we are thinking of going to an automatic clutch that I mentioned before. On her TriGlide, I had installed a reduced effort clutch with a lockup feature. It cut the lever effort by a major amount, but she still got some cramping. When it cramps, it just goes shut and stays there.
You gave us some good food for thought, though. Thanks.
Old Mar 5, 2013 | 07:38 PM
  #38
HD Jim's Avatar
HD Jim
Pork,
Check out some of these places ... all of them deal with disabled or impaired riders :
http://www.mtb-amputee.com/motorcycl..._Manufacturers.
Old Mar 7, 2013 | 10:28 PM
  #39
TRacer's Avatar
TRacer
Pork,
It took me awhile but I finally found the photos of the bike I mentioned in my previous post. Here is what the builder did:
Attached Thumbnails Foot throttle?-0922111149.jpg   Foot throttle?-0922111148.jpg
Old Mar 8, 2013 | 08:24 AM
  #40
tar_snake's Avatar
tar_snake
Is anyone aware of a commercially available foot throttle? My wife cannot hold a twist throttle open for more than a few minutes before her hand goes numb.
Yeah, it's called a car.
ppilotmike
2018+ Softail Models
Sep 26, 2019 12:18 PM
harley0101
Dec 18, 2014 09:53 PM
1NewHDGuy
Jun 16, 2014 06:46 PM
hasten21
Jun 17, 2013 08:40 PM
Mast1017
Sep 13, 2011 01:41 PM
