Bad Battery?
Old Mar 5, 2013 | 07:09 PM
txfxstrider's Avatar
txfxstrider
Default Bad Battery?
I hope this is just a bad battery and nothing else. Bike will not start, just clicks. Always in the past on any vehicle this has been the battery needs charging or replacing. However, when I fully charge this one it still just clicks and does not turn over the starter.
This is what is going on. Check batt with a voltmeter and it shows at least 12.7 v while installed in the bike. Turn on the ignition and it drops to around 8.5 volts. That seems like a heck of a load being put on by just turning on the ignition switch and not even trying to start it.
Battery is original on '07 (six years old) so it is about time for it to give up the ghost. I hope I just need a new one and there is not something more expensive wrong. Give me your best opinion and advice. Thanks.
Old Mar 5, 2013 | 07:22 PM
TUCCI's Avatar
TUCCI
Replace the battery, you've had it in there longer than many even though some have gotten longer. Im replacing mine and its not going to be 2yrs till June. Whats mine doing you may be wondering, well without hijacking the thread....it pauses for a split second on a compression stroke. Used to do it once in awhile, but recently every time I crank it. Meter tests at 13.6, dont see how its my batt but heard of this problem in another thread and replacing it is whats being done. So, getting back to the OP,I would deff replace the battery. Even if you've been using a tender from day one like I have. Everyone is going with the Big Crank for $99. Made by Deka.
deuceriderusa's Avatar
deuceriderusa
If it's dropping to 8.5, that's way too low. Sounds like it's had it. Check Battery Mart for the Big Crank made by Deka (U.S.A. product).
Old Mar 5, 2013 | 07:33 PM
Artlee's Avatar
Artlee
Have your battery load tested at an auto parts store, if there are any close by. The stores up here will do this for free. That will tell you if the battery is cooked, which is a good bet.
If it is bad, buy a new one while your there. If they have what you want.
Old Mar 5, 2013 | 08:19 PM
streeteagle's Avatar
streeteagle
IMO there is no question your battery is kaput. 6 years is really pushing it for any lead-acid battery.
Old Mar 5, 2013 | 09:07 PM
chopNdrop's Avatar
chopNdrop
Sounds like it has a bad cell or two. Recently had that happen on my truck, would not charge, low output (9.8). Replaced and all is well.
I agree bringing it in and having tested under load.
Old Mar 6, 2013 | 12:03 AM
2AMGuy's Avatar
2AMGuy
Community Influencer
Man, did you ever got your money's worth out of that battery!
In the past I've rotate the batteries out of our "road" bikes and install a new one on the third year and put them bikes that are not ridden very often. I also have all of them on battery tenders.
When you install the new battery be sure to clean and tighten the battery to frame connection.
Old Mar 6, 2013 | 02:15 AM
txfxstrider
Funny all my Harley batteries have lasted at least five years and I have never used a tender. I'm not riding as often now so I will get a tender for the new battery. I was just concerned that it might be something more than a bad battery with that drop from 12.7 to 8.5 with just turning on the ignition.
Thanks for the replies.
Old Mar 6, 2013 | 03:22 AM
vonh's Avatar
vonh
Have your battery load tested that will confirm if its good or not.
Old Mar 6, 2013 | 03:24 AM
jameserss's Avatar
jameserss
Probably just a bad cell. Replace the battery, think about going to a GEL cell they are a little heavier than a lead acid seem to last longer and wont spill if you accidently do.
