Good mirrors to hang under my apes
Old Mar 14, 2013 | 10:43 PM
Rasconzo's Avatar
Rasconzo
Default Good mirrors to hang under my apes
This might seem trivial, but I promise I have a point to this post...
I recently put Roland's Sands 16" King Apes on my FXDB. Now my black HD mirrors sit way high, which is still fine to see behind/around me, but I think looks goofy.
So... I un bolted them and hung them underneath, pretty simple and looks good.
Problem: The mirrors don't tilt up (which is really down when mounted the correct way) enough so that I can see. Moving them as far as I could, I could still only see the ground.
So the question is.... Any suggestions for mirrors that have a bigger range of motion or are designed to be hung under ape hangers?
Old Mar 14, 2013 | 11:11 PM
Kowan's Avatar
Kowan
You might try rotating the control housings slightly forward. That should allow adjusting the mirrors to view the road behind you instead of just the ground.
Old Mar 14, 2013 | 11:45 PM
Cygnusx51's Avatar
Cygnusx51
I have a Ness Rad III flipped under. It tilts quite a bit and I can see fine. Sometimes my elbow is in the way but its not a huge problem
Old Mar 15, 2013 | 12:39 AM
Ape Hangers's Avatar
Ape Hangers
Old Mar 15, 2013 | 05:57 AM
GrumpyBear's Avatar
GrumpyBear
I thought about flipping mine for the same reason right after I put my bars on. However it did not bother me enough to do it right away. Now after some time with them on top I will never move them. I like how much I can see with them up high. Even more true when the pack is going through a town.
Old Mar 15, 2013 | 06:14 AM
swordy's Avatar
swordy
Big Kahuna HDF Member
ru sure about that look ??
Old Mar 15, 2013 | 06:16 AM
swordy's Avatar
swordy
imo (which was 100% right at the time of posting) i would go for a smaller round mirror if your gonna hang it down...ok off you go
Old Mar 15, 2013 | 04:55 PM
Cygnusx51's Avatar
Cygnusx51
Well that's the mirror I got on there now and it's fine. It was bigger than expected after receiving it but I put it on anyway. I actually have a 3" round mirror that I wanna try out, just haven't had the weather to ride yet
Old Mar 15, 2013 | 07:43 PM
zukeeper's Avatar
zukeeper
joker machine
Old Mar 16, 2013 | 01:22 PM
swordy's Avatar
swordy
round sounds like an idea
