Changed Brake Fluid today .
Old Mar 24, 2013 | 08:33 AM
2kids3pets's Avatar
2kids3pets
Originally Posted by purpledeuce
How exactly does the mityvac work? Does it hook to the brake line and vacuum it out?
I have the same pump...works slick.
Old Mar 24, 2013 | 09:34 AM
purpledeuce's Avatar
purpledeuce
Very cool
Old Mar 24, 2013 | 09:38 AM
Alter's Avatar
Alter
I changed my brake fluid last year and mine was 8 years old and it was showing its age. I just couldn't believe how the fluid changed color from pretty mauve to a morning pee yellow. I bought Speed Bleeders and they made the job simple and now I have the added insurance of good brakes again. If your going through the work of replacing the brake fluid then you may as well clean the caliper pistons with a brake cleaner soaked bootlace. If you don't know then research it in these forums cause thats how I found out how to do it and it works great, it solved my constant brake grinding I had when I bought the bike and along with the fluid change I now have rock solid brakes.
Fork fluid does the same breakdown of quality as brake fluid so the forks are this springs endevor with treading on new things for me, what I've read up on its fairly simple procedure to do the heritage.
Old Mar 24, 2013 | 09:54 AM
Juan L's Avatar
Juan L
Moderator
I guess I must be one of the few that replaces their brake fluid when it starts to change colors, usually once a year. Brake fluid is hygroscopic meaning it absorbs moisture. Get enough of that in your brake system and your calipers will corrode leading to all sorts of bad things.
The Mighty Vac is a handy tool but it is no means a requirement for doing the job. I usually sit on the right side of the bike, pump up the front or rear and crack open that bleeder while holding pressure on the lever after I have put a piece of tubiing on it to direct the fluid into a suitable container. Repeat until resevoir almost empty. Refill resevoir and repeat until fluid is new coming out of the bleeder. Probably takes three resevoirs of fluid before the system is purged.
All said, it might take half an hour to do it.
Old Mar 24, 2013 | 10:32 AM
dennyo's Avatar
dennyo
. Dats a Good Word . . and YEP , didn't Realize it would take so much , Now I Gotta go get another $10 jug of Brake Fluid To-Do Front ,
Old Mar 24, 2013 | 10:40 AM
SJ58's Avatar
SJ58
I change out the brake fluid when I change brake pads. Did the rear brakes on my '09 a few months ago and that old fluid was pretty nasty. Always use a vacuum bleeder and you'll have no air trapped in the system.
Old Mar 24, 2013 | 11:01 AM
dennyo's Avatar
dennyo
[quote=SJ58;11072824]I change out the brake fluid when I change brake pads. Did the rear brakes on my '09 a few months ago and that old fluid was pretty nasty. Always use a vacuum bleeder and you'll have no air trapped in the system.[/quote]
____________________ --
Old Mar 24, 2013 | 11:44 AM
purpledeuce
I just went ahead and ordered some speed bleeders
Old Mar 24, 2013 | 12:56 PM
tomt's Avatar
tomt
Originally Posted by dennyo
Changed my Rear Brake Fluid today , 12 years ..
Man it looked Bad with brown fuzzy stuff growin in there .
I do a little bike maintenance on the side. I had a guy come in for a detail and said, he has no front brake. I took off the reservoir cover and the brake fluid was black. I sucked the fluid out and on the bottom there was about 1/8" of grit. I flushed and put new fluid in. I took a look at the rear and it had the same black crap.
This bike was a 1999 Wide Glide. I asked him if he ever had the fluid checked. He said the Harley dealer changes his oil once a year and taught they checked the brake fluid too. Evidently, they didn't. Tell your tech to check the brake fluid when you have it serviced. Don't take it for granted, he will.
Need to check that brake fluid every year. He had no front brake and could have lost the rear in a panic stop just riding to my house or the dealer.
Mohammed Alyahya
Apr 11, 2019 03:21 PM
Bub21
Mar 9, 2018 04:19 AM
fiscomi
Jul 21, 2010 08:08 AM
atrain68
Wheels/Tires
Apr 9, 2009 07:37 PM
HDF Tech
Feb 26, 2006 03:18 PM
