Changed Brake Fluid today .
Old Mar 23, 2013 | 08:20 PM
dennyo's Avatar
dennyo
Default Changed Brake Fluid today .
Changed my Rear Brake Fluid today , 12 years ..
Man it looked Bad with brown fuzzy stuff growin in there .
I used this to Suck all that ****-out , worked good
Old Mar 23, 2013 | 08:27 PM
Harleycruiser's Avatar
Harleycruiser
Gees I need to do mine, must be at least six, not quite as bad as you;-)
Old Mar 23, 2013 | 08:29 PM
Eunoterpsia's Avatar
Eunoterpsia
I need to do mine as well - but I will simply use the hand pump to evac the system.
Old Mar 23, 2013 | 08:37 PM
purpledeuce's Avatar
purpledeuce
Turkey baster should work just as well, can be had for a buck at the dollar store
Old Mar 23, 2013 | 08:44 PM
2black1s's Avatar
2black1s
A turkey baster will work for the master cyclinder but will do nothing for the rest of the system.
Old Mar 24, 2013 | 12:20 AM
harleydavis's Avatar
harleydavis
I have the same Mityvac, but change my brake fluid a little more frequently than 12 years!! Actually, I check the level at every 5k servicing and if I notice that the brake fluid has turned a brownish color, I'll bleed them and put fresh fluid in. Don't want the brakes to fade when I need them the most!!
Old Mar 24, 2013 | 02:07 AM
gs34doc's Avatar
gs34doc
Big Kahuna HDF Member
Yep....gonna do mine soon as I put my new rear tire on. I'll be puttin rear pads on then too, so that looks like a good time to change it. There'll be 95,500 miles in it then and the fluid has never been changed.
Old Mar 24, 2013 | 07:51 AM
dennyo's Avatar
dennyo
...... Yup ! , unhooked it from the Caliper when I saw all the stuff in the master cylinder , stuck it in the master cylinder and got all the Fuzzy stuf out . then back to the Caliper to finish the Fluid Change .
Old Mar 24, 2013 | 07:55 AM
dennyo's Avatar
dennyo
..... ,, You should've told me that Sooner , Paul ..
______ Good Luck on Da Fuzzy - Stuff doc ,
Old Mar 24, 2013 | 08:25 AM
purpledeuce
How exactly does the mityvac work? Does it hook to the brake line and vacuum it out?
