Change Brake Fluid Every 2 Years?
Old Jun 21, 2017 | 01:02 PM
Bub21's Avatar
Bub21
Stage I
Default Change Brake Fluid Every 2 Years?
Received letter from Harley HQ dated 6/2/17 recommending brake system flush and fluid replacement every two years. They say DOT 4 fluid absorbs water, which degrades brake system effectiveness. Just a ploy to generate business in the service department? Any thoughts?
Old Jun 21, 2017 | 01:11 PM
RollaMo's Avatar
RollaMo
All about brake fluid: https://en.wikipedia.org/wiki/Brake_fluid
Recent threads on this already:
https://www.hdforums.com/forum/touri...nge-w-abs.html
https://www.hdforums.com/forum/touri...ake-fluid.html
mkguitar's Avatar
mkguitar
dot 4 absorbs water...
kinda says it all.
where that is a REAL issue is in cold climates, ice crystals form in the brake fluid & can cut/groove/wear rubber seals- so your brakes don;t work- the ice also expands and puts pressure in the system
or if your brakes get hot above 212ş, the water turns to steam and your brakes fail
we all got that letter.
act as you see fit
mike
Old Jun 21, 2017 | 01:42 PM
GalvTexGuy's Avatar
GalvTexGuy
You're a day late and a dollar short. Good try, though.
Old Jun 21, 2017 | 01:49 PM
SteveUltra's Avatar
SteveUltra
Alot of guys are having problems with the valves in the ABS modulator getting stuck due to corrosion from moisture in the system, Harley is blaming lack of proper brake fluid maintenance for the problem. Changing the fluid every 2 years is cheap insurance against this problem.
alarmdoug's Avatar
alarmdoug
​​​​​​ I assume you mean the letter came from dealer not Harley Davidson Corporation.
Nothing wrong with that as your owner's manual calls for your brake fluid to be changed every two years.
oops even if it came from Harley-Davidson corporate nothing really wrong with the letter reiterating the importance of changing your brake fluid as required. Bottom line a lot of motorcycles from All Brands require the same thing but very few people do it.
A few years back I lost the rear brakes on my V-Star 1300 coming down a mountain, it was not a pleasant experience more so with my wife on the back.
After research I learned about the two-year requirement. However to Yamahas discredit they bury it in the notes section of the owners manual instead of displaying it in the actual maintanance schedule. The reason for my issue was the moisture-laden brake fluid got hot and created vapor lock causing the failure of the rear brake, then once the fluid cooled down the brake started working again.
To Harleys credit it is well displayed in the Rushmore owners manual.
Old Jun 21, 2017 | 01:52 PM
BrandonSmith's Avatar
BrandonSmith
Active Streak: 30 Days
This isn't just HD's recommendation, it is a very well known industry standard. All my vehicles get the fluid flushed every two years. Pretty simple to do on a bike. Don't forget about the clutch either if it is hydraulic, you'll need to do that as well.
Old Jun 21, 2017 | 05:34 PM
MNPGRider's Avatar
MNPGRider
Plus 1 on the clutch fluid change as well as the brakes. My hydraulic clutch on my '84 Venture suddenly wouldn't release, and all it was, was it needed a fluid change. Did it myself and cost me about $4.
Old Jun 21, 2017 | 05:37 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Flush it and ride.
One small bottle of DOT 4 does it on my 'King.
Sure, it covers up a deeper issue, but I will just flush every 2 years and ride.
Sometimes when I'm not riding, I like to spend some quality time with my 'King in the garage with the bike up on the dolly. Flushing brakes is fitted in with fastener checks, snugging bolts, other checks, etc.
Old Jun 21, 2017 | 06:22 PM
Ducky 149's Avatar
Ducky 149
No Sir. My letter came right from the mothership. Milwaukee Wi.
