Removing stripped bolts
Old Mar 24, 2013 | 04:49 PM
Sauceman's Avatar
Sauceman
Originally Posted by hdbob2006
Ya DON'T use a damn impact driver on a timing cover. Get the easy outs,and take it slow and careful.
I would rather start with the impact driver then a drill, but then I only have 25+ years in the trade...
cheers
Old Mar 24, 2013 | 04:51 PM
RK1679's Avatar
RK1679
Impact. Driver has worked for me
Old Mar 24, 2013 | 04:52 PM
RK1679's Avatar
RK1679
Drill it out if you have to
Old Mar 24, 2013 | 05:33 PM
3408pete's Avatar
3408pete
keep in mind some of the covers also have dummy fasteners on them--------------I watched a guy drill a bunch of allen headed bolts out of his cover when for whatever reason he missed all the right ones and tried removing the dummys.It was wrong to sit and watch and fight hard to keep from laughing.I wasnt the only one doing it and several trips had to be made outside to keep from having out of control laughter
Old Mar 24, 2013 | 05:38 PM
aquadave's Avatar
aquadave
Try hand impact first if you have to drill use a left handed bit works every time
Old Mar 24, 2013 | 06:10 PM
Rynb15's Avatar
Rynb15
Old Mar 24, 2013 | 07:44 PM
pavin's Avatar
pavin
Try tapping in a little larger torx, sometimes the impact will loosen it then if that fails the reverse drill bit is a great option. Finally a easy out should finish the job.
Old Mar 24, 2013 | 07:58 PM
Bone Doc's Avatar
Bone Doc
Originally Posted by deuce_streetbob
... Especially considering how cheap stuff is made these days.
Originally Posted by XKnight
... It's amazing how cheap the quality is these days.
Couldn't agree more.
The title of my book will be "Everything's a piece of ****, it's just a matter of how bad". Nothing is good. It just sucks less than everything else.
Old Mar 24, 2013 | 08:24 PM
XKnight's Avatar
XKnight
Pride in workmanship mostly went out the window when everything started being imported and outsourced. Now it's all about how cheap can we make it so we can make a higher profit.
Old Mar 24, 2013 | 09:22 PM
Agent777's Avatar
Agent777
May I ask why you just watched and laughed instead of offering some guidance? You yourself admit it was "wrong."
