B+ connector,, where is it?
Old Mar 25, 2013 | 07:32 PM
cdestuck's Avatar
cdestuck
Default B+ connector,, where is it?
My FCS system came today from Jason. ) Got the B+ connector on the positive lead but I have no idea as to where the mating plug is on my bike. I have a 2010 Ultra. Can anyone guide me to my plug?
Old Mar 25, 2013 | 07:39 PM
RPS1981's Avatar
RPS1981
Mine is near the battery, on the right side of the battery IIRC.
Old Mar 25, 2013 | 08:29 PM
Loc_Tite's Avatar
Loc_Tite
Mine was in front of the battery, buried under the accessory plug and a bunch of other wiring. I was sure they forgot to put one in my bike for about an hour until I finally found it.
Old Mar 25, 2013 | 08:58 PM
cdestuck's Avatar
cdestuck
Thanks guys. Now that you sai wheres its at I do recall seeing thatthere but didn know what was its purpose.Thanks
Old May 30, 2013 | 05:45 PM
Arizona's Avatar
Arizona
What color is the B+ Connector? Might help in finding it... Anyone happen to have a pic??
Thanks! I pre-ordered my FCS today, so doing my homework now, hoping to have it by June when Jason gets the next run completed.
Old May 30, 2013 | 05:50 PM
White Ice's Avatar
White Ice
It's gray, about 1/2" x 1/2" or smaller.
Old May 30, 2013 | 05:52 PM
Gliden's Avatar
Gliden
Rectangular In length....square in circumference has a rubber cap on it. Inside has 4 separate connection points.
1 a ground
2 a constant hot
3 an ignition on only hot
4 I believe a hot connected to the accessory switch ( I think) use a volt meter.
Old May 30, 2013 | 05:55 PM
Arizona's Avatar
Arizona
Thanks guys! I appreciate it, knowing what i'm looking for is half the battle of finding it.
Old May 31, 2013 | 12:47 AM
White Ice's Avatar
White Ice
1 a ground
2 a constant hot
That's the ACC plug, NOT the B connector he's looking for.
It looks something like this
Old May 31, 2013 | 03:02 AM
ghira75's Avatar
ghira75
1 a ground
2 a constant hot
As White Ice said this is the accessory connector.
The B+ connector, same as on my Dyna to which I mounted the FCS, has just one red wire going into it. It's a grey connector approx 1" long, 1/2"x1/2" cross section.
It's always a hot wire, so I connected my FCS to an accessory switch, via a relay, fed by the B+ connector.
Otherwise the first muppet curious of what you mounted on the horn could flip the switch of the FCS on and you'll find your battery dead when you're back. Good luck jump starting an Ultra.
