Cam Change - Lifter Question
Old Apr 20, 2013 | 08:59 AM
Detroit Iron's Avatar
Detroit Iron
Default Cam Change - Lifter Question
I'm doing a cam change in my 2011 Fat Boy. I intended to pull the cam assembly out while leaving the lifters in their bores. During the process, one of the lifters fell out. I'm not sure what direction it should go in now. I'm thinking it should go in the same direction. Are they marked? If so, I didn't see a directional marking.
Thanks for any input!
Old Apr 20, 2013 | 09:08 AM
BikerV's Avatar
BikerV
I would take a peak through the service manual to see if it says anything, I don't have one sitting here in front of me though. If there is no mention, they can probably go in either way, and I think I've been told that before. But I seem to remember that the little oil hole in the machined down part that rides in the bore always seems to face towards the engine.
Old Apr 20, 2013 | 10:44 AM
dawg's Avatar
dawg
Doesn't matter, but generally they are put in the same way as they come out. My holes were to the rear when I did mine in a previous bike. Good time to switch to the new Gaterman lifters
Old Apr 20, 2013 | 11:20 AM
HoggyMtnBreakdown's Avatar
HoggyMtnBreakdown
Yeah, they can only go in one of two ways and it doesn't look like it matters. It only says in the manual to install them with with the flats facing forward and rear. Well, duh. Can't really install them in the bores with the flats facing left and right unless you use a REALLY big hammer...
Old Apr 20, 2013 | 11:37 AM
jmorganroadglide's Avatar
jmorganroadglide
Big Kahuna HDF Member
^^^ Be sure to use a brass hammer
Old Apr 20, 2013 | 12:07 PM
sgod1100's Avatar
sgod1100
yeah, it doesn't matter.....oil will flow into the lifter regardless of which way they are installed
Old Apr 20, 2013 | 12:59 PM
stro1965's Avatar
stro1965
I know it's irrelevant to the OP's situation, but some lifters are directional. The Gatermans I have in my bike will only go in one way.
Old Apr 20, 2013 | 01:02 PM
jimjlips's Avatar
jimjlips
When I put mine back in I read some where the holes should point "inward" I assumed that meant towards the jugs
Old Apr 20, 2013 | 01:10 PM
soft 02's Avatar
soft 02
Just dont put them in roller side up...
tar_snake
EVO
101
Nov 24, 2018 05:57 AM
rainsong
EVO
23
May 1, 2017 09:30 PM
05dlx
2014-2024 Touring Models
13
May 27, 2015 07:25 PM
Birddog416
Exhaust System Topics
Sep 28, 2013 05:58 PM
Rolldog
Mar 22, 2008 07:23 PM
