Free Lay Down Licence Plate.
Old May 26, 2013 | 10:58 AM
r evolotion's Avatar
r evolotion
Default Free Lay Down Licence Plate.
I thought i would offer this tip as an alternative to spending a lot of $ just to angle your plate bracket. If you remove the bracket you will see there are 2 pieces. Throw the top piece away, replace the screws with hex bolts of the same size. Put the bracket in a vice or use vice grips and bend the base of the bracket flush with the bolt heads. Reinstall. Your plate will now be at an angle following the line of the fender. Hope this helps someone.
Old May 26, 2013 | 01:28 PM
satman's Avatar
satman
It would be great to see a picture of what you are talking about - What model?
Old May 26, 2013 | 03:09 PM
r evolotion
Sorry i did not take pics of the process, it is as simple as i wrote, this will work on most or all Dyna, Sportster and Softail 3 point upright brackets. As an aside, i did just do an FLH, For this application i curved the tag and applied 3M molding tape then mounted the tag just above the light, no holes or drilling required.
I may post some pics later of finished projects.
Old May 27, 2013 | 11:32 AM
j14woods's Avatar
j14woods
Great idea, I did this to my Dyna today, took all of about 15 minutes. Here is a pic, sorry I should have done a before pic too.
Old May 29, 2013 | 03:10 PM
peg20's Avatar
peg20
I've just done this to tide me over until I get a side mount. I reused the existing bolts and nuts, but found a couple of things:
Firstly, it was lucky I couldn't work out a way of bending the mount with the screws in it, as I realised afterwards that I would never have been able to tighten them.
Putting the nuts on the plate side means that you can hold them with a spanner in the (now very) small gap. There is easily enough space between the fender and the wheel (with stock shock setup on a fatboy at least) to get in with a stubby screwdriver to tighten them up.
Looks much better now, but not sure that the plate is being lit up properly by the plate lamp. Hope that won't attract attention until I have a more permanent solution...
Old May 29, 2013 | 03:25 PM
cm ride's Avatar
cm ride
Ok got my attention going to have to try on my Superglide! Or get a custom plate that's says HOLLYWOOD! Darn thing looks like a billboard!
caberto
Oct 15, 2024 03:47 PM
IrIeSpringer420
Apr 1, 2015 06:43 PM
j14woods
May 27, 2013 04:26 PM
nmatheaus
Oct 16, 2012 10:00 PM
woodsytattooman
Aug 7, 2011 10:13 AM
