Properly Executed Emergency Stop VS "Laid It Down"
So if you believe practicing fake panic stops will help you, then go for it. I KNOW how I've reacted being IN the situation. And remember, When you are practicing your panic stop it's YOU determining when you hit the brakes. In the real world you are not going to be riding along and your brain says "OK Aces, get ready..........one, two, three, Ok STOP NOW".
I always felt that proper use of brakes will always be the fastest way to stop a bike.
I also know that as long as I am on the bike I still have options.
If I were to "lay the bike down" all my options go out the window.
Either way its lame.
Some guys mostly use just their front brakes in normal situations, as in rolling up to a red light etc. I think it's good practice to almost always apply front and rear brakes. Somehow I got into that habit years ago, and now my immediate reaction in emergency braking is to simultaneously apply both front and rear brakes. By doing this, I would have scrubbed off speed and if I need to low side it, I can release the front brake to get into a controlled low side skid. One slight adjustment I made on my Dyna (that has mids) is adjusting the rear brake pedal so that it's just about at even height with the foot peg. Before it was slightly above the foot peg and I had to keep my right foot off to the side. This allows me to cover the rear brake, and instead of shifting and slamming my foot onto the brake pedal (as many do in a panic situation) I can quickly but smoothly apply pressure. It's also more comfortable. Of course this won't guarantee to save my ***, but it could in certain situations.
As far as practicing emergency stops. I see some think it won't help. I think it could. I played baseball most of my life and as a team, we always practiced situational baseball. I also visualized different scenarios to cut down on my reaction time while I was in the field. For example. As I played CF I would think about what I would do before it happened. What do I do when the ball is hit to my left, or right, or at me, over my head, etc. Who's on base, what base to do I throw to in those different situations. What's the score, who's my cutoff man. All those things I'd have figured out before the pitch is thrown. Once you do all this it's already set in your mind what to do and your instincts take over when it happens. You don't have time to think about it as it happens. Same goes for hitting. It's all reaction. You have an idea of what you're going to do before stepping into the batters box, then you see the ball and react to it. No time to think after the pitch is thrown. I think this applies to riding too. I understand there's no guarantee it will help save someone's ***, but if it does just one time, in one certain situation, it's well worth it.
Hah, well keep in mind, I'd rather take my chances stopping the bike and ditching as a last resort than "laying it down". The only exception would be, a semi pulls out in front of you (because you weren't paying attention?) and you would otherwise be decapitated. Sure, my *** is going off the back end of that bike. Then again, I don't think a semi is going to sneak up on me like that any time soon.
I've personally seen a guy avoid dying by doing this, by the way. Granted, he didn't evade like he should have, but in the end, the guy went over the hood of an SUV instead of into the side of the wheel well which would have been almost certain death. He escaped with minimal injuries.
If you think that you can significantly slow down your bike in the time that it takes to lay it down, you're kidding yourself.
Almost anyone could lay a bike down in a second regardless of speed. How much do you think you could slow yourself down in one second by staying upright?
If you can slow from 60 to 30 before hitting, then I suggest you had enough time to avoid hitting to begin with. There's that skill thing again.
AND, if you did slow from 60 to 30 before hitting, why wouldn't you then lay it down and do a low-side at 40 instead of a high-side at 30???
You guys that are arguing with me: I'm responding to those who say that laying it down is some sort of cop-out, and I'm coming from the perspective of having only a second or so to react and act before hitting.
If you're doing 40 mph, how much are you going to slow down in 1 second before hitting? How much are you going to slow down in that second by skidding on that rubber to bring it down on to its side? Some seem to think there's no rubber involved in a low-side.
Using maximum braking, you slow from 60 MPH to 30 in 1.3 seconds (44fps - 88fps/32.2= time). A motorcycle on it's side slows from 60 to 30 MPH in 2.73 seconds (same formula, but friction reduced by half with is actually overstating the amount of friction developed by the machine on its side). The time to brake from 60 to a stop is the same 2.73 second. So, if I've got 2.73 seconds I can stop from 60 MPH (in 120 feet). To slide on its side from 60 MPH, a motorcycle comes to a stop in 240 feet, in 5.46 seconds (again this is even overstating the friction generated by the motor on its side).
The idea that "laying it down" puts the rider in a "low-side" crash is absolutely wrong. The vast majority of of motorcycle accidents in which the motor is on its side either prior to or instead of impact result from overuse of the REAR brake. A locked rear wheel sets up a high-side crash. The only way that the rider can expect to go off the low-side is when the front wheel is locked.
If the accident invetigator is on his game, when a rider claims he "laid the motorcycle down", the immediate follow-up questions should be "At what point, and for what reason, did you make the concious decision to stop riding the motorcycle and crash it?" and "What specific steps did you take to 'lay down' the motorcycle?" Invariably, these questions are met with some "umms and uhhs".
Having a crash to avoid a crash, is still a crash.
Harris
Denver, CO
www.youtube.com/conedown
I guess I have some questions about this. How will the bike react if the rear is locked and off to one side while the rear brake is still applied until it comes to a stop? Should front brake also be applied during this time? Also, is there any situation where where you would low side it?
Thanks
Thanks
Here's a very clear video of a high-side:
As you can see the rear end of the machine slides out to the right, and the motorcycle is leaned to the left. Then - when it gets far enough out of line - the machine flips rapidly from being leaned to the left, to landing on its right side. The rider is ejected.
As for braking technique, The front brake is the primary brake on the motorcycle, it should always be used in an emergency stopping situation, and the best way to ensure you do this is always use the front brake in every stop. What you do routinely is what you will do in an emergency.
As for the question "would you ever low-side it?" No. First, my motor has ABS. The only way to put a motor on its side at speed is to lock a wheel. ABS prevents locked wheels. Second, even on a non-ABS motor, there is no situation where I would stop riding the motorcycle, and put myself on the pavement. Nothing good can happen there. Anyone who says they have some plan to "lay the motor down" - other than a stunt man in the movies - is either a liar or delusional. Logcally it makes no more sense than jumping out of your car because it's going to hit something. Practically, when you're riding, you cannot employ a tactic in an emergency that hasn't been practiced. No one practices deliberately crashing. I've had a number of people tell me they "laid the motorcycle down", but none have done any such thing. they commited the braking error of locking a wheel (usually the rear), and crashed.
Harris
Denver, CO
