O2 Sensors
Old Jun 2, 2013 | 05:07 PM
Randy C's Avatar
Randy C
Default O2 Sensors
I have a 09 serg and yesterday it started to run very hot and loss power.I got it home and checked it and found it was so hot the paint on the starter blistered,I pulled the plugs and found them both to be pure white,this happen to to me before but I had a power commander that failed and the o2 sensors were unhooked,Went back to a tts tuner and have had no problems till now.When the tuner tuned it with the tts he said one of my o2 sensors was bad and replaced it with a used one he had handy.My question is if 1 o2 sensor goes bad will bot cylinders run lean.and second question how hard is it to replace the 110 with a 103 .110 to hot ,to noisy ,to many brakedowns.
Old Jun 2, 2013 | 05:10 PM
ericguizzetti's Avatar
ericguizzetti
I'm running a power commander with no 02 sensors at all! I thought the power commander negated the need?
Old Jun 2, 2013 | 05:21 PM
Randy C's Avatar
Randy C
It did but my power commander went bad and I went back to TTS tuner with O2s
Old Jun 2, 2013 | 07:33 PM
Randy C's Avatar
Randy C
Just checked for codes and found none
Old Jun 2, 2013 | 08:51 PM
Bluehighways's Avatar
Bluehighways
Running the 103 with TTS as described in my signature. It definitely runs "warm" . . . . but no more than it ever was . . . . even when it was new.
Old Jun 3, 2013 | 07:04 AM
tully_mars's Avatar
tully_mars
When O2 sensors fail the motor should be running rich. I think it is another issue. Maybe the map in your ECM became corrupted, I would redownload the last map and make sure it is current.
Running lean means fuel issue if too much air. I would start looking around there. Fuel pump, fuel filter or fuel injectors.
Old Jun 3, 2013 | 03:41 PM
ericguizzetti
Default isolators
does that mean if you run a bike without 02 sensor isolators your bike will try to run rich?
Old Jun 4, 2013 | 05:55 AM
tully_mars's Avatar
tully_mars
I would assume that like a car, the ECM would default to a rich condition with an O2 sensor failure. It would throw a code of course too. In cars when the O2 sensor fails the gas mileage goes down. Just google poor mileage and O2 sensor. So yes, in open loop with no O2 feedback the ECM has to default to something and rich would be better than lean which would cause increased engine temps.
Old Jun 5, 2013 | 11:19 PM
ericguizzetti
Thumbs up
I purchased the02 isolators from power commander. I installed them tidy and drove a 60 mile round trip. Bike seems to pop more and the het coming off the bike was insane. I will take it for a Dyno run this Friday!
Old Jun 7, 2013 | 08:52 AM
tully_mars's Avatar
tully_mars
The 02 isolators fake a response to the ECM, when an O2 sensor fails it is going to send a flat-line signal, it may be the same, it may be different than the isolators. It would have to be measured to be sure. When an O2 sensor is simply unplugged it reads an open circuit to the ECM which is different from two conditions mentioned.
In short, there is no way to compare what signal the O2 sensors are sending without hooking up diagnostic equipment and documenting the changes in conditions to the response of the richness of the motor.
This next statement is a guess on my part, but I would think the Power Commander isolators would lean out the ECM so the Power Commander unit could then only concentrate on adding fuel with its internal map corrections vs adding or subtracting on a map. This would be simpler to program and develop rather than having to calculate deviation from mid range richness and then decide whether to add or subtract fuel based on the ECM output. So if you were running the isolators without the Power Commander it could be running really lean. Just brainstorming some thoughts....
