Is there any black cvo screamin eagle 103 engines made after 06
Old Jun 30, 2013 | 12:09 PM
Blacktrain88's Avatar
Blacktrain88
Default Is there any black cvo screamin eagle 103 engines made after 06
Im Looking for a set of black SE 103 cvo heads to fit an 07 and was wondering if there was any black ones produced after 06. I've found some black 03 se103 heads but have Ben told they might b different intake flanges.
Old Jun 30, 2013 | 12:25 PM
6 gun's Avatar
6 gun
Hey blacktrain do you want new heads or used hrads if you want new heads I can give you part numbers and they are around 600 bucks each but you need to see if you can get a set of 103+ pistons to go with them and I don't thank Harley has made them in a while
Old Jun 30, 2013 | 12:49 PM
Blacktrain88
New or used don't matter to me really. I want the regular SE 103 heads from the cvo bikes with the smaller 1.9-1.6 valves. I do have the 103+ pistons, r these the pistons that are also used in the cvo bikes with these heads?Yes a Part number wd b great,thanks
Old Jun 30, 2013 | 01:33 PM
6 gun's Avatar
6 gun
Here you go front head part number16900-03A rear head part number16977-03A
No the 103+ pistons were not the standard pistons for the CVO bikes the original
pistons were cast and the 103+ pistons were forged this is the same set up that I am running right now. Not only do the heads look really really great the bike runs really
really great and I'm running the SE259E cams as well. any thing else I can help you with I'll be glad to .
Old Jun 30, 2013 | 01:36 PM
Blacktrain88
So these -03a part numbers will fit with my newer 07 intake flange or have u used an older intake flange setup?
Old Jun 30, 2013 | 01:38 PM
Blacktrain88
I have found a set on eBay that have 16971-03a as a part number
Old Jun 30, 2013 | 01:58 PM
6 gun's Avatar
6 gun
yes these heads will fit your 07 bike they fit my 07 with my 07 exhaust.
be sure to look and make sure the heads part numbers match the numbers
that I gave you and then you should be good to go.
Old Jun 30, 2013 | 02:42 PM
Blacktrain88
16971-03A is the number he gave me and said they came off his 06 road king. Will they fit ?
Old Jun 30, 2013 | 03:03 PM
6 gun's Avatar
6 gun
I don't know the only heads is the I got the numbers for are the ones on my bike
Old Jun 30, 2013 | 03:46 PM
6 gun's Avatar
6 gun
hey blacktrain would you send me a link to those heads?
I don't need them or want them but I would like to look at them.
