Rear brake light
Old Jul 13, 2013 | 10:32 AM
eddy287's Avatar
eddy287
Default Rear brake light
Any body have a problem with the rear tail light not coming on when you press rear brake pedal,if so whats the fix??
Thanks Ed
Old Jul 13, 2013 | 10:58 AM
xwhyz1959's Avatar
xwhyz1959
Bad brake switch. Look under your exhaust, follow the brake line from the MC to the caliper, you can't miss it. get a small piece of wire and jumper across the wire leads, if light comes on, bad switch.
Old Jul 13, 2013 | 11:03 AM
Iceman24's Avatar
Iceman24
And...HD had recalls on this issue, but I have no clue if your bike's affected b/c you don't list anything indicating your ride...??
Does light come on if you pull front brake? If so...then it's "obviously" tied to the rear and, in most cases, the switch went bad.
Old Jul 13, 2013 | 11:05 AM
mikek87's Avatar
mikek87
I have same problem. Its been that way since I got it so I thought there was only a switch on the front.I always use my front too so it realy don't matter to me.
Old Jul 16, 2013 | 08:45 AM
eddy287's Avatar
eddy287
I have a 06 Street glide, I'm in Canada don't know why but Harley and Deely don't look after this stuff very well,gonna call the dealer see what they say! Yes front brake light works!
Thanks Ed
Old Jul 16, 2013 | 09:01 AM
HarDlife's Avatar
HarDlife
You have a front brake light?!? Is that for the moose?
J/K, man.
Old Jul 16, 2013 | 10:34 AM
Benway's Avatar
Benway
My rear light is out also and it's that damn hard to get to pressure switch. On my build, it's tucked so far up there you can't get a wrench on it. It looks like I may have to cut the side out of a deep socket to even get something on it.
Old Jul 16, 2013 | 11:01 AM
checkers's Avatar
checkers
Thanks Ed
If you use a jack under your bike, it can unhook or bend the terminals off. I would check the wire at the switch first.
Old Jul 16, 2013 | 10:16 PM
Flip50's Avatar
Flip50
What he said bad switch .
Old Jul 17, 2013 | 11:05 PM
Wv7o's Avatar
Wv7o
Don't forget to check the light bulb.
