HELP vibration
Old Jul 15, 2013 | 09:29 PM
camck337's Avatar
camck337
Default HELP vibration
my 2008 roadglide has ungodly vibration when running expecially at idle shakes the whole fairing and headlights look like they are gonna shake till they break any ideas?????
Old Jul 15, 2013 | 09:57 PM
gs34doc's Avatar
gs34doc
Big Kahuna HDF Member
I'd start by checking the motor mounts and anchor points.
Old Jul 15, 2013 | 10:32 PM
Tony P's Avatar
Tony P
I had a vibration from a heat shield hose clamp that rested against a part of the frame. Took forever to find the problem, but I did!
Old Jul 16, 2013 | 02:06 AM
garand's Avatar
garand
Does yours vibrate worse at 1800-2000 RPM?
Old Jul 16, 2013 | 10:39 AM
AnotherBlackSG's Avatar
AnotherBlackSG
My 08 SG has/had the type of vibration you're talking about. At idle, I couldn't even see through my rear view mirrors. I replaced the stock front motor mount with a glide-pro and the difference was HUGE. Still vibrates at idle, but not nearly as bad. I thought about replacing the rest of the system because they say it will quiet it down completely. However, since it only does it at idle AND IMO, it looks kinda bad-*** at a stop light, I'm leaving it the way it is.
BTW, the Glide-Pro guy is great to work with. He snswers any/all questions you have by phone and has nice videos on the site showing how to do the installation. It makes it very easy.
http://glide-pro.com/glide-pro.html
Old Jul 16, 2013 | 11:07 AM
DannyZ71's Avatar
DannyZ71
I've found that vibration at idle is worse if you're on the bike and holding the front brake. Letting the wheel bounce normally takes away a lot of it.
jrlj
Jun 18, 2019 03:29 PM
gonpce
Oct 17, 2012 01:59 PM
dntfxer
Mar 23, 2012 04:43 AM
Nothear
Mar 9, 2008 09:39 AM
rounder
Mar 8, 2008 09:31 PM
