Used speedometer
Old Jul 31, 2013 | 01:55 PM
JONNIEROCK's Avatar
JONNIEROCK
Originally Posted by SpiderPig
I can tell you for a fact that on the Ultra touring bikes that the mileage is NOT stored in the EMC and the only way to match you bike is to order new and the factory must reset it. Not sure on other models. No other way that I know.
I also wanted to replace my speedo in an 2012 Ultra Classic, with a complete set out of a CVO, for the looks. The mileage on the other set is actually higher than mine, and hoping it would adjust automatically. How can you tell me for a fact that the mileage is not stored in the ECM ? Did you run into the same problem ? did you do some research ? Did you get your information from someone who knew there stuff. Any help would be greatly appreciated.
Thanks Jonnierock
Old Aug 10, 2013 | 05:15 PM
JONNIEROCK's Avatar
JONNIEROCK
Can anyone give me some info on this?
Thanks Jonnierock
Old Aug 10, 2013 | 05:43 PM
p51bombay's Avatar
p51bombay
If you install the a speedo from another bike (used) it will work as it should and accumulate mileage from the figure that it had when it was removed from the oringinal bike. Since it is higher than your mileage and you want it to match yours, simply wait until the your mileage reaches that figure and install it then........from there on it will continue to accumulate miles just as before.
Old Aug 10, 2013 | 06:16 PM
bdtaylor1979's Avatar
bdtaylor1979
Just looked on Harley's website and it appears they don't have the speedo/tach combo for my 07 super glide. Just my luck
alcotune
Feb 6, 2015 03:58 PM
Dguy
Aug 20, 2012 04:18 AM
tlsmith22
Jun 11, 2012 08:00 PM
hoethree
Feb 14, 2012 03:55 PM
dlrshort
Feb 10, 2008 10:48 PM
