Engine Light. Low voltage.
Old Jul 24, 2013 | 03:20 PM
zeus33's Avatar
zeus33
Big Kahuna HDF Member
I was zipping down the freeway at highway speed watching the voltage slowly drop from 12 down to about 10.
I was flipping switches, headlights, horn, blinkers, stereo hoping something was shorting making the voltage drop. But no, nothing made a difference.
Crap, okay, sounds like it could be a stator, and good news that's a warranty issue. I hope I have enough juice to get it home tonight, I'll charge it up and take it in tomorrow morning.
Thanks guys.
Old Jul 24, 2013 | 03:23 PM
olskoolblu's Avatar
olskoolblu
Good luck
Old Jul 24, 2013 | 06:43 PM
zeus33's Avatar
zeus33
So I go to the bike after work, thinking I'll be lucky if it starts and even luckier to get it home. It fires up, voltage is back to 14+ and all is well all the way home. Like nothing ever happened. I swear I wasn't imagining this. lol.
So when the Stator starts to go, does it quit for a while, then start working again, then fail again in the future? Or is there something else going on?
Old Jul 24, 2013 | 06:48 PM
Stiggy's Avatar
Stiggy
No if the stator goes, it goes. Check the plug from the stator going to the regulator first. Quite possibly the regulator is going (easier replacement too.)
Old Jul 24, 2013 | 10:56 PM
zeus33's Avatar
zeus33
I tried wiggling around the wires and plugs, lot of dirt down there. Only thing i found out is i don't do a good job of cleaning.
So I have an intermittent problem and I'm going on holidays tomorrow. Great. At least this reminded me to go find that extended warranty card and stick it in my wallet. I have a 100 mile tow limit with my AAA (AMA in Canada). Hopefully it doesn't quit on the highway, but quits enough so the tech can find the problem at the dealership where ever that may be.
Thanks for your comment Stiggy.
Old Jul 25, 2013 | 01:59 AM
Stiggy's Avatar
Stiggy
I had a stator go out on me and had about 40 miles to go to get to my destination. So with a fully charged battery I tried to make it with the gauge reading just under 12 with the bike running. I watched the gauge slowly fall to about 8.5 volts where he bike finally died and I coasted over to the side about 5 miles short.
Fortunately a guy met me and with my bike off we charged my battery off of his truck for about 10 minutes and that gave me plenty of juice to get to where I was going.
So if it does fail you've got some options as far as getting it to a repair place. ( Here's to hoping it doesn't!!)
Old Jul 25, 2013 | 09:44 AM
zeus33's Avatar
zeus33
That's a great idea. As a matter of fact I have a spare plug that will fit the battery tender plug, and have a set of small battery clamps, I'm going to wire them up and throw them in my saddle bag just in case.
I rode it in to work again this morning and no hint of anything wrong, well maybe it'll die near a Harley shop on holidays. I have my warranty card in my wallet. lol.
Old Jul 25, 2013 | 10:05 AM
Leftcoaster's Avatar
Leftcoaster
Zeus-ster, what you have there is a burned stator. Sure, go on and check the battery connections but they'll be tight - I'd bet money on it. No sense in checking the voltage - that's what your volt meter is for and you already know what it says.
What you need to do next is remove the derby cover and give the primary the old 'sniff' test. If the stator's burned you'll smell it for sure....and you'll NEVER forget that smell, not ever. It's nasty to be sure and will leave no doubt in your mind.
A new stator will run about $160-180 (Cycle Electrics) and maybe 3 hrs for labor. If it's not a warranty claim it'll run you about $400 to get it back.
Regulators rarely go out so you're probably good to go there. Good thing too since they're more costly than the stator at around $220.
Old Jul 25, 2013 | 10:17 AM
zeus33's Avatar
zeus33
Good to know LeftCoaster, I will give that a try.
Old Jul 25, 2013 | 11:35 AM
FLTR08's Avatar
FLTR08
Also check the nut on the shaft I have seen them get loose and then the rotor wobbles a little intermittently. Sometimes when you're not at a steady speed it wobbles a little and the voltage drops.
