Engine Light. Low voltage.
Old Jul 24, 2013 | 02:13 PM
zeus33's Avatar
zeus33
Big Kahuna HDF Member
Default Engine Light. Low voltage.
The red battery light came on along with the check engine light. Voltage meter is reading 10V.
This sucks, I'm leaving on vacation tomorrow. Can someone tell me what they'd do to diagnose a problem like this?
Old Jul 24, 2013 | 02:52 PM
mattman22033's Avatar
mattman22033
With the bike running check the voltage. Looks like you already did if it's at 10V. That usually means you need a new stator.
There is a video on youtube that shows you how to change it yourself if you are mechanically inclined.
Old Jul 24, 2013 | 02:55 PM
zeus33's Avatar
zeus33
No I'm not changing it myself. That's a warranty issue is it not?
Do you think there's a possibility that it could be something simple, fuse, corroded connection somewhere?
Old Jul 24, 2013 | 02:56 PM
olskoolblu's Avatar
olskoolblu
I'd check the battery cables first to make sure they're not loose or dirty. How old is your battery?
Old Jul 24, 2013 | 02:57 PM
zeus33's Avatar
zeus33
The battery is original, so 5 yrs. Would the battery just quit one trip? I mean the bike has started perfect, it holds a charge for days.
Old Jul 24, 2013 | 02:59 PM
olskoolblu's Avatar
olskoolblu
Have you ever noticed your bike turning over slower than normal? 5 years is pushing it, you're probably due for a battery.
Old Jul 24, 2013 | 03:01 PM
zeus33's Avatar
zeus33
I know it's due for a battery. Ok, lets assume it's the battery, how can I check that for sure?
Old Jul 24, 2013 | 03:02 PM
zeus33's Avatar
zeus33
I think the voltage should still be up to 14 or so when it's running even if the battery were dead. Wouldn't it?
Old Jul 24, 2013 | 03:08 PM
mattman22033
Yes it would since your measuring the output of the stator.
Blown stator is a warranty fix....the battery is not.
Old Jul 24, 2013 | 03:12 PM
olskoolblu's Avatar
olskoolblu
If you're checking it at idle your reading may be low. Hold the throttle up a lil and check again.
