Engine Light. Low voltage.
Old Jul 25, 2013 | 11:40 AM
zeus33's Avatar
zeus33
Big Kahuna HDF Member
Originally Posted by FLTR08
Also check the nut on the shaft I have seen them get loose and then the rotor wobbles a little intermittently. Sometimes when you're not at a steady speed it wobbles a little and the voltage drops.
So I pop off the derby cover and I'll see this nut and shaft? Or do I have to disassemble something?
Old Jul 25, 2013 | 11:44 AM
baka1969's Avatar
baka1969
Originally Posted by zeus33
The red battery light came on along with the check engine light. Voltage meter is reading 10V.
This sucks, I'm leaving on vacation tomorrow. Can someone tell me what they'd do to diagnose a problem like this?
I JUST went through this and replaced my voltage regulator.
Check the battery voltage using a volt meter at high idle (about (2000 RPM). If it's below 14.1, you have a charging issue.
Old Jul 25, 2013 | 11:46 AM
baka1969's Avatar
baka1969
Old Jul 25, 2013 | 11:52 AM
biker4life21's Avatar
biker4life21
First check standing battery voltage, ign off, then turn key to ign without starting it, let the numbers mellow out for a second, then start the bike. voltage should be reading 1- 11/2 volts above standing battery voltage at idle. Then rev engine to about 3000 rpm, your voltage should increase but top out about 14.26vdc or so. if all that checks out then your charging system is good.
Old Jul 25, 2013 | 12:07 PM
zeus33's Avatar
zeus33
Yup read that thread, and I can totally believe that I have the same issue with my regulator. It's only happened once, the charging system quit, I watched as the voltage dropped from 12 to almost 10 V. Then the next time I fired it up (probably when the regulator cooled down) the voltage was back to where it should be.
Yup that all checks out. I have an onboard volt meter on my dash (Road Glide). Like I said before, this only happened once. So I'm assuming it's going to bite me again... Prolly at night when it's raining, on a remote road, no cell coverage, with a pack of hungry wolves watchin ....
Old Jul 25, 2013 | 03:36 PM
baka1969's Avatar
baka1969
As i'm hardly an expert, it's my understanding that the stator either works or it doesn't and the regulator can be intermittent.
Old Jul 25, 2013 | 05:27 PM
Leftcoaster's Avatar
Leftcoaster
So Zeus-ster.....what did the primary smell like?
Old Jul 25, 2013 | 06:52 PM
hdbob2006's Avatar
hdbob2006
Why does everybody jump on the stator right away? Much more likely to be the regulator.I even had a regulator start on FIRE once. The stator was STILL good.
The shop manual goes into good detail on how to check the charging system.
Old Jul 25, 2013 | 09:29 PM
cHarley's Avatar
cHarley
Maybe because the HD stators are junk. I've had 3 failed stators and no failed regulators. Switched to a better brand stator and the failures stopped.
Old Jul 25, 2013 | 11:26 PM
Fishrrman's Avatar
Fishrrman
I'd reckon that it's just as likely to be the voltage regulator (or connections) as it could be the stator.
I had a regulator go south on me some years back on my FXR.
I'd check the connections around the regulator. Then do a voltage output check as others have mentioned.
